na-t project concerns sc300 1992
First off, I'm looking for no more than 400rwhp on my sc300 92. I've gather pretty much everything to complete the swap, but 1 major concern is the ecu shutting off the car during boosts over 12psi. I've heard the sc300 stock ecu can't handle over 12psi. What can I do in this situation? I don't plan on using any expensive electronics like aem, or fcon stuff, but I may consider buying the s-afc if neccessary. I've heard that the gm 3bar map sensor would take care of the issue of increasing the fuel pressure psi without the ecu shutting off. If so, how do you install this 3bar map? I know it's installed and attached on the ecu harness as a few wires are neccessary to be used from that harnest. As for the afm, which is on top of the intake filter pipe, do we have to remove that? I've heard that the ls400afm would swap over perfectly, but that 25% extra airflow seem to cause a whole mess of trouble as far as fuel issue goes. I don't want to mess with that. Please help me in anyway you can.. Much appreciated!! thanks guys.
I would suggest doing a whole lot more research before taking on this project. Let me help get you started:
1) Sounds like you're referring to fuel cut, it does not exist on these cars since they are not turbocharged from the factory, regardless the ECU never 'shuts off' under any circumstances.
2) You will need some sort of fuel mgt at the least, not necessarily the 'expensive electronics' as you call them, but you will be very limited with just an S-AFC.
3) A MAP sensor won't and can't alter fuel pressure on it's own, it simply senses manifold air pressure. In deference to what you said re: this and the MAF, sounds like you're referring to the difference between an airflow meter and a speed density metering system....i'm not one of these automatic 'use the search engine' ppl, but it will help you greatly since you seem to only have a crumb of knowlege when properly turbocharging a Lexus coupe is more like a seven-course meal.
Hope that gets you started, nothing is more important than doing the proper research and then taking the time to do it right. Good luck.
Originally posted by aliga
As LL stated fuel cut will only occur on the factory turboed cars.
You also mentioned that the LS400 maf would cause some trouble, can you elaborate on what you have heard? They are plenty of guys that had plenty of success using this maf.
Former Sponsor
Are you j0hnnyboi? If so, Im not helping you. I take all my info back. Its funny how you switched your name up, trying to get help after disrespecting me before.
http://www.supraforums.com/forum/sho...hreadid=152027
Find out more about fuel injection systems, and how they work. Specifically, the role a MAF plays, and the role a MAP plays. Then find out how the ECU detects and shuts down with overboost. Also learn more about turbocharging a car. Corky Bell's book would be a good start.
Forum Administrator
WadeLovell
Performance & Maintenance
12
03-14-14 11:51 AM
vinh
SC400 / 300 Classifieds
09-06-13 12:25 PM
CmputerWiz
SC- 1st Gen (1992-2000)
12-08-01 05:42 AM
