Rare Cross Traffic Alert is no longer working!!!
Hi guys!
Today, I just realized that when I back the car up, the rare cross traffic alert warning sound is no longer work. I am not sure when it stopped working. I pulled into another parking lot, and I tried again when there are cars passing, the warning is not showing up at all. I checked my BSM, it is on too. Very confused about it. Anyone having the same problem or know how to fix it?
Thanks a lot!
Thanks a lot!
BSM main switch
Pressing the switch turns the system on or off. When the switch is set to on, the switch’s
indicator illuminates and the buzzer sounds. This switch is for both Blind Spot Monitor
function and Rear Cross Traffic Alert function.
It would seem if BSM is working, it should, too. Do you get the flashing mirror indicators for cross-traffic? Could simply be a buzzer issue.
Be aware that Park Assist (small disc sensors on the F & R bumpers) is a Proximity Sensor,
when an object is within the 2 - 5 foot range it chimes until either you or the object move apart.
The BSM/RCTA is a motion sensor (hidden sensors in rear fenders), When an object moves into
its 5 - 65 foot range it chimes. If it stops moving but is still near you the warning ceases.
BSM main switch
WOW! guess what, it works now!!! It was on left, and i just put to right and switched back to left. and it worked now! I don't know how is that even possible, i didn't know that is how to fix it?? haha. thank you so much again.
You're welcome. It drove my nut the first time too.
biacs
10-11-18 08:04 AM
