headlights -aim, and gear shift questions
I have triple beam headlights. it seems that the right and the left hit the ground at different locations. do others notice this? not sure if i need to ask the dealer to adjust but that concerns me that they wont get it right and could make it worse.
also, on my shifter, i find that the leather handle can be turned clockwise and counter clockwise. is this an issue or do others find this too
The pursuit of F
I never noticed any lighting angle differences. Get it checked out for alignment.
Shifter **** rotating is normal but it should not feel loose. If it does, you can simply unscrew it (counter clockwise) and add a thin layer of electrical tape around the base thread so it becomes tighter when you screw it back on.
Rickster31
06-27-07 02:59 AM
