Oil filters: 90915-20004 or 90915-YZZB9?
Old 05-22-03, 10:19 AM
Sovero1
Sovero1's Avatar
Default Oil filters: 90915-20004 or 90915-YZZB9?
I have a 93 GS300 with an inline 6 engine. When i tried ordering 90915-20004 they advised against it, saying that it's bigger than 90915-YZZB9 and is only recommended for V8 engines.
Can someone please explain the difference between using a bigger vs. smaller oil filter on a 6-cylinder engine? Is there any advantage to using a bigger filter? Also, both filters are made in Japan, and if there is no harm in using a bigger one, which part number should i order?
Thanks in advance,
Ed
Old 05-22-03, 12:40 PM
meZoom!
Super Moderator
meZoom!'s Avatar
i'm positive 90915-20004 is made in japan but i'm not sure bout the ones beginning in yz.....
i've used the -20004's in my V6 before, no problem. theoretically, a bigger filter=more filtering capacity.
order the 20004 if you're comfortable w/ the price. i doubt you will see significant changes though. i didnt, but i still used it.
Old 05-24-03, 11:19 AM
dickpribyl
dickpribyl's Avatar
for reference, my '03 RX300 came from the factory with 90915-2003, obviously it is made in japan and this was stated on filter.
at first oil change I replaced it with, 90915-YZZB9, also made in japan. it stated on filter body that it (YZZB9) was compatible with 90915- 2003. Both were Denso.
Old 05-25-03, 02:07 AM
kreativ
kreativ's Avatar
There are 4 kinds of Denso filters (made in Japan) you can get for your Toyota/Lexus:
90915-20004: What comes factory-installed on V8 Lexus engines. Taller than 20003.
90915-20003: What comes factory-installed on 6-cylinder Lexus engines
90915-YZZB5: Cheaper version of 90915-20004. Some are adament in claiming they're the same without having actually examined the two filters. But see this ClubLexus thread to read gebo's dissection results of the two filters.
90915-YZZB9: Sounds like the 90915-YZZB9 is to the 90915-20003 as the 90915-YZZB5 is to the 90915-20004. Haven't seen this filter myself though.
The 20004 will provide the most filtering capability of the 4, and is the highest quality OEM filter you can get. Many Lexus owners with 6 cylinder engines opt for this filter.
Old 05-25-03, 03:39 AM
meZoom!
Super Moderator
meZoom!'s Avatar
I just picked up a -20004 today from carson toyota!! $8-and change! Just holding that filter in my hands makes me giddy. yeah, i'm retarded.
Fritz330
13
07-16-14 11:00 PM
love67
07-04-09 01:37 AM
hugo2648
RX - 1st Gen (1999-2003)
08-04-07 04:46 PM
XxSC400xX
02-01-06 09:17 AM
jimbo36
09-08-01 09:10 PM
Quick Reply: Oil filters: 90915-20004 or 90915-YZZB9?
