Is250 HELP!!
Is250 HELP!!
I have a 2006 Is250
Today my check engine and VSC lights came on and I tried to use the pulling 2 fuses to reset the ECU
after I reset the ECU the car will no longer rev as I depress the accelerator
The car will idle and run it will just not rev as it should
I am at a loss and help is appreciated
Maintenance Moderator
Good chance there is something going on with the throttle body... all vehicles take some time to relearn driving habits once they have been completely reset, some are more noticeable than others... always a good idea to have the codes pulled so that we can fix the issue, not just ignore it...
without being there, unfortunately, hopefully the check engine light comes on and you can get the codes pulled and report back to us... if not, it needs to go in for service...
welcome to the board, hope we can help!
Shumba
Build Threads
10-18-16 05:15 AM
