Driver brake pads wearing faster than my passenger
Car:
98 Lexus GS400
Supra TT Front calipers + plain Brembo rotors.
so i checked my pads the other day and noticed that my driver pads were about 1-2 mm less thick than the passenger side. Also 2 months back i had my rotors resurfaced and noticed that my driver rotor was the warped one..
and lastly when removing the caliper on the passenger side from the rotor (after removing the 2 bolts holding it) the caliper slides off easy even with the brake pads. Doing the same to the driver ide have to give it a tug and wiggle it out.
oh wait one more.. when applying the brakes the driver side tends to make crunching sounds at one certain point of the rotation
whats the deal with this? is it possible that my driver caliper is slowly failing/seizing n needs to get rebuilt?
98 Lexus GS400
Maintenance Moderator
There is one other possibility and that is a bad brake hose... hoses can come apart internally and allow fluid to travel to the caliper under high pressure, but not return as easily, as the return is only affected by the square cut seals on the caliper pistons...
Definitely worry... if they are opened at all, you will need to go through the bleeding process, else risk introducing air into the system... as cheap as brake fluid is, if you are doing any work on the system at all, it would be a good idea to completely replace the fluid...
wald.sc400
05-24-11 07:27 AM
