Oil Filter Question
Yes. I drove the LFA.
If you are going to use an aftermarket filter, i would just be sure to use a name brand, high quality filter. Essentially, both an OEM filter and an aftermarket filter do the same thing, some better or worse than others. If you have any doubt, just stick with an OEM filter. At least you know its a tried, true tested filter that the manufacturer stands behind.
Lextranny
RX - 1st Gen (1999-2003)
02-22-05 10:18 AM
