Cabin Air Filter
FWIW, the RX330 has the cabin air filter just forward of the glove box. Open the glove box and look on the side panels of the glovebox for two ****-looking stops that keep the glovebox from falling all the way open. If the setup is the same, rotate the ***** 90 degrees and pull them out of the side panels. The glovebox will open further. The cabin airfilter should be inside that area toward the firewall. You can grip the small handles and pull toward you. The air filter will be right there.
Chris- hopes this helps
joedaddy1
07-31-12 11:37 AM
