Has anyone ever replaced ... (engine fan oil and power steering oil)
Has anyone ever replaced ... (engine fan oil and power steering oil) UPDATE
Has anyone ever replaced engine fan oil and power steering oil. I am working on a 95 SC400 which has been sitting in the garage for the last three years and want to replace all fluids before the car gets put back into full time service. I tried searching, but was unsuccessful. Any help on this topic would be greatly appreciated. Thanks!
Update
Yesterday evening I have flushed the power steering fluid, transmission fluid, differential, engine fan, and break fluid. All I can say is OMG! It is a new car again. I have never thought that the difference can be so dramatic. After the power steering flush the steering feels a lot tighter and more responsive. The transmission shifts so smoothly that you cant even tell that the gear has been changed. Even when you place it in D or R there is no more jerking. The breaks are so responsive that just by touching the pedal the car stops almost immediately and the pedal feels very firm. Once again I have never expected such a result from just plain fluid changes.
Yesterday I have also switched to Mobil 1 synthetic. I think the engine is running even smoother now. I am very impressed!
Total cost for all fluids including coolant was approximately $220. Trans fluid and coolant were the biggest expenses because these fluids are only available at the dealer.
Fluids used:
Motor oil – 5W30 Mobile 1
Trans Fluid – Toyota T-IV
Power steering fluid – Pennzoil Dexron III/Mercon
Engine Fan fluid - Pennzoil Dexron III/Mercon
Differential fluid – Valvoline 80W90
Break Fluid – Prestone Synthetic Dot 3
Coolan – Toyota Long Life (50/50 Mix with Distilled Water)
Fluids used:
Excellent ! !
It's amazing how fresh fluids will perk a Lexus up .... Reasonably priced too
( siphon out the washer fluid, run some distilled through the system, drain and refill with fresh premixed. )
Nice!
I only drained and refilled my tranny fluid but the difference is amazing though. I do 95% city driving and my tranny shifts almost every 5 seconds (in between stops) so I nkow it takes a beating. It got to the point where it gets jerky so now i'm going to drain and refill everytime i do an oil change.
BTW how did you flush the power steering fluid? My fluid is brown now so it's time for it to be flushed, or at least drained. I guess I can get a pump and pump out the old fluid from the top. lol.
I'll be doing differential soon. I bought myself 2qts of Redline gear fluid (75w-90)
__________________
1999 Lexus GS400
-Stock
Your user account may not have sufficient privileges to access this page.
__________________
1999 Lexus GS400
-Stock
