Inner Tie Rods -do they wear out?
Old 11-13-05, 08:45 PM
John U
John U's Avatar
Default Inner Tie Rods -do they wear out?
Both outer have been replaced. It has a shimmy again so it stands to reason it has to be the inners (rotors are new). I've seen the photo's of inners and ask, What wears on them? They look like a solid rod with a bushing on the end.
Or could the steering rack be the problem?
Thanks,
JU
'94 ES300 145,000 miles
Old 11-14-05, 06:53 AM
Tammy
Tammy's Avatar
Suggest you have it put in the air and have the steering rack checked through it's entire lock to lock range, comparing the amount of play in the rack from lock to center by wiggling the front tires. I believe the inner tie rods are part of the rack assy. At the same time check for wear in the front wheel bearings and ball joints.
Old 11-22-05, 08:14 PM
John U
John U's Avatar
Turns out it was the rotors!!!
While I replaced the drivers side axle ($65.00 at Napa) (boot was ready to break) and replaced the ball joint ($40.00)(Why not replace it when you have to unbolt it anyway to replace the axle) I figured I'd toss on two new rotors ($41.00 ea - Checker).
Took 4 hours to complete the job. I figure I saved $200+ in parts markup and $350+ in labor.
I love saving money!!!!
I just turned them 4,000 miles ago and they warped again. (Yes, I torque wrench the lug nuts) The new ones are a lot thicker compared to the 145.000 mile turned once originals.
Later,
JU
Old 11-23-05, 06:56 AM
Tammy
Tammy's Avatar
Yea...... The aftermarket's are sometimes not quite "up to par". But they're half price so I understand the risk. Glad you got it resolved !
Old 11-23-05, 01:32 PM
John U
John U's Avatar
Originally Posted by Tammy
Yea...... The aftermarket's are sometimes not quite "up to par". !
You're right on the money.
I make sure I'm buying a branded names premium line. Some of the no name imports or even the branded products budget lines are somewhat suspect.
Later.
JU
Rozay604
09-01-23 03:54 PM
crcuevas
46
01-06-23 12:40 PM
j2b4o
02-06-17 02:36 PM
ashtray
Suspension and Brakes
14
04-27-14 09:09 AM
Lexus082
09-29-07 05:22 AM
Quick Reply: Inner Tie Rods -do they wear out?
