any smog techs, need help!!!!
i had to go to test-only and failed the 25mph with high nox. any suggestions as to how i can pass?? i lowered the timing to 8-9 degrees. the smog tech said it was at 12 degrees
Super Moderator
Even though your EGR may show functional...there could be something dirty in there causing the NOX to go just over the limit. I doubt it it is a bad cat or O2 sensor as your other values look very good, especially your HCs. Even though you were under the limit on 15 mph for NOX, those NOX values still look high to me in relation to the other types of emission values your are showing.
top engine cleaner
how about using some top engine cleaner?? would that help bring down the readings??
the pcv valve is new installed a few months ago, so i think i sholud be good with that one
is that the stuff you pour in the tank when 1/4 empty and then you fill it up and drive around in??
before u go into ur next emmision test do this
oil change
run your engine hard on the way to the emision station
and when ur inline for the emission test. hold your rpms at 2500.
it sucks to have to go to test only. havent had no time to get around to getting it smogged. since i have to go to test only now, in the future would i have to go back to test-only for my next smog??
