ac went dead need help!
yesterday i was having alil fun around noon time and it was pretty hot so i had the ac blowing...i stepped on the gas on a S onramp griping the road pretty hard and flooring it till around 65..outta no where my a/c turned off now it wont turn back on..the defrosters dont work too the whole thing dont work..only the back lights turn on... what can it be? did i blow a fuse ? did the whole climent control broke or is the whole a/c con shot?anyone have any insught on this? i hope its only a fuse
Do you have a sight glass for the A/ C in front of the condensor (in front for the radiator)? does the compressor clutch energize? Do you see any bubbles? You may have blown a hole from a rock in the condensor. If the freon has leaked out, the pressure switch shuts down the system. Need to meter Hi/Lo pressure ports to know for sure.
Segzy14
07-18-18 01:00 PM
BilluAwan
12-07-08 09:20 PM
