Which service sked should I follow?
I have an 03 GX470. Dealer seems to want me to come in for every possible maintenance stop (They make good money). I dont drive in any bad conditions (dust, traffic, etc). What are the major services I SHOULD get and how often is evveryone changing their oil? I've been changing every 5k. Dealer says 3k (which is what I used to do) and manual says 7.5k.
Opinions?
177mph
Opinions?
177mph
I think time between oil changes is a factor too. If you drive 15k-mi/year or more, I think your 5k-mi/ oil change interval is what I would do. I only do about 10k-mi/year, so my oil change intervals are in the 3-4k-mi range.
I tend toward doing some things based upon time (e.g., coolant change, brake fluid change) and others based upon milage (e.g., tire rotation, A/C filter change). I think other things, like wiper blade replacement, depend on factors like whether the car is garaged 24/7 or left outside all the time.
From what I've read, the biggest over-serviced item appears to be transmission fluid. The owner's manual and even the dipstick (at least on my model) say it shouldn't be changed if it keeps it's cherry-red color.
here's what I try to follow
LEXUS MAINTENANCE SCHEDULE
Every 3,750 Miles:
Oil and Oil Filter Change
Every 30,000 Miles:
Coolant Flush/Change
Air Filter Change
Every 60,000 Miles:
Spark Plugs Change/Tune Up
Transmission/Differential Fluid Flush/Change
Power Steering Fluid Flush/Change
Brake Fluid Flush/Change
Battery Check/Change
Every 90,000 Miles:
Timing Belt Change
Water Pump, Thermostat, Cam Seals, Idlers, Tensioners, etc. Change
Hoses Check/Change
Air Conditioner Filter
Every 1 Year:
Exterior Wax
Wiper Blade Inserts Change
Every 3,750 Miles:
Every 30,000 Miles:
Air Filter Change
Every 60,000 Miles:
Every 90,000 Miles:
Timing Belt Change
Hoses Check/Change
Every 1 Year:
Exterior Wax
moto12345
03-29-11 01:15 PM
khoaly000
03-24-09 10:59 AM
