FS: 4300k HID Conversion Kits - 9006 / H1 / H3
Old 10-06-08, 03:41 PM
TRC
TRC's Avatar
Default FS: 4300k HID Conversion Kits - 9006 / H1 / H3
Brand new 4300K HID Conversion Kits fits 9006, H1 or H3.
Each kit is in its original packaging and has never been installed. Price per kit is $180 + shipping.
For more information, please see XenonDepot.com. Description below.
The Xtreme Digital Xenon HID Conversion kits utilize cutting edge Xenon HID components made with superior Japanese craftsmanship and quality to offer you the latest in High Intensity Discharge (HID) Xenon technology. To ensure optimal light output, the Xtreme HID Kit uses laser calibrated bulbs so that the focal point of the HID bulb matches the focal point of the corresponding halogen bulb. This will result in both proper fitment and optically correct beam patterns. Industry leading AMP style connectors are used to ensure proper water tight connections between the HID bulb and HID ballast.
- Patented Digital Ballast Technology for precise colour illumination
- Japanese quality and craftsmanship
- CE, UL, and E4 certified OEM Grade Xenon HID Components
- Epoxy sealed Waterproof and Shockproof HID Xenon Ballasts
- Laser aligned HID Xenon Bulbs to ensure optically correct beam patterns
- Unique dual relay harness design
- Full replacement warranty
The HID ballasts used in this product are uniquely designed for aftermarket HID Xenon applications as they are completely epoxy sealed to protect against harsh weather conditions. In aftermarket HID conversion kit applications, ballasts are often mounted outside the headlight leaving them susceptible to water damage. The Xtreme ballasts are specifically designed for these applications making them the superior choice for your aftermarket HID conversion kit upgrade.
BALLAST SPECIFICATIONS:
- Xtreme HID Digital ballasts are designed with a patented multi stage safety feedback (M.S.S.F.) system allowing them to interact with the bulbs to determine optimal light output.
- Xtreme HID Digital ballasts use a patented self intelligent light output configuration (S.I.L.C) to ensure brightness stability and precise illumination colour.
- The Xtreme HID Digital ballasts are designed for both 12V and 24V applications.
- Equipped with advanced polarity protection system
This HID conversion kit will include a complete wiring harness that will literally plug directly into your OEM headlight harness via proper mating connectors. The harness provided will include upgraded fuses and relays to ensure you do not draw a higher current from your stock wiring harness than it was designed to provide. Unlike many HID conversion kits on the market, our HID kit will use a dual harness set up that will provide each ballast its own fuse and relay.
Xtreme HID converstion kits are manufactured in an industry leading ISO and TUV certified high tech facility.
HID TECHNOLOGY:
XENON HID lamps do not have a filament. Instead the light is created by an electrical discharge between two electrodes in an air tight tiny quartz capsule filled with xenon gas, mercury and metal halide salts. This improves durability as road vibrations can cause damage to coil lighting technologies. These light sources also produce a blue-white light that is safer because it is closer to natural daylight. The color temperature is approximately 4200 K compared to 3200 K for halogen. The increased light output from a 35 watt XENON HID lamp is approximately 80% more light then a 55 watt halogen bulb. The XENON HID system will also draw less power from your vehicles electrical system.
COLOUR TEMPERATURE:
Color Temperature is a measurement in Degrees Kelvin that indicates the hue of a specific type of light source. Many people believe the misconception that colour temperature is a rating of the brightness of the bulb or HID kit. This belief is completely false. The reality of the matter is that the higher the colour temperature, the less useable light output you will obtain. A perfect example would be a black light. This light has a colour temperature of approx 12,000k and has almost no useable light or lumens output. Our Xtreme Xenon HID Conversion kits are available in a wide range of colour temperatures to suit each individual application. Our Xtreme Xenon HID Conversion kits are available in 4300k HID, 5000k HID, 6500k HID, 8000k, and 3000k Yellow HID
TRC is offline
Gregz_IS
03-01-12 12:23 AM
VNN326
05-15-08 04:33 AM
vdt04452
Lighting
12
11-25-06 11:19 AM
Quick Reply: FS: 4300k HID Conversion Kits - 9006 / H1 / H3
