LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
drive shaft greasing
Old 02-03-14, 01:39 PM
lx20072014
lx20072014's Avatar
Default drive shaft greasing
been searching for the clunk noise that i have in my car for awhile. it comes out a second when releasing the brake paddle.
don't LOTS of research and found out that the drive shaft has to be serviced with every oil change.
some folks say the moly grease works better than synthetic grease.
my questions:
1- anyone had experienced with moly grease and what is the outcome?which one is better?
2- has anyone figured out how many pump take the slip yoke zerk? i know the U joint take pumps till it ooze out the old one.
Any help is appreciated it.
Old 02-03-14, 06:50 PM
kwatt1
kwatt1's Avatar
The issue is a known problem. There is a thread tha ttalks about replacing hte driveshaft. The issue is the design of shaft itself. If you grease it regularly, it reduces the clunk but it likely will not eliminate it. The new design driveshaft is $500-$600. I only hear the clunk occassionally and it doesn;t bother me enough to replace the driveshaft/. Maybe when the universal joints let go.
Old 02-04-14, 02:39 PM
lx20072014
lx20072014's Avatar
i did read the threads in CL and ih8mud but not sure to go with the synthetic grease or moly!!
some say moly will last longer. anyone experienced this please share !!
Old 02-04-14, 08:29 PM
kwatt1
kwatt1's Avatar
ITs not a grease weearing out issue. It's a grease filling the gap issue so i don;t think it will matter.
Old 04-04-14, 02:36 PM
faast
faast's Avatar
Have your mechanic take out the rear drive shaft and lube the Splines with Moly fortified Multi-purpose grease. Once done then he can lube the rest.
I had mine done about 10,000 miles ago and I barely feel the jerking.
Old 04-04-14, 05:21 PM
Max707
Max707's Avatar
3 pumps in every Zert, every oil/filter change.
Old 09-14-14, 05:57 AM
krye
krye's Avatar
Just greased by 2000 LX. Universal joints took 2-3 pumps for grease to leak out. Put 15 pumps in slip joint, and the noises went away. Have been greasing every 10K miles. Front fitting require removing 8 bolts to remove shield. 4 of the bolts broke this last time requiring drilling and tapping from below. Will replace all bolts with stainless steel before winter.
shyguyF
GX - 1st Gen (2004-2009)
05-17-17 06:30 AM
Vinniety
02-13-13 08:32 AM
FERNDOGGS3
09-01-11 04:49 PM
ShibbySC4
Performance & Maintenance
09-15-10 08:07 AM
bear1
17
12-10-03 01:03 PM
Quick Reply: drive shaft greasing
