LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Old 12-12-14, 03:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Print Wikipost
Replacing Rear ACH Shocks
Old 11-20-10, 11:07 AM
MNiern
MNiern's Avatar
Question Replacing Rear ACH Shocks
I have a 2000 LX with leaking rear shocks and 125k miles. I found the Lexus part numbers 48530-69107 at a local dealer for $191.37 each. I also purchased 2.5L of ACH fluid for $40.79.
The ACH system works fine and except for low fluid level in the tank, has no problems.
Should I drain and replace the ACH fluid from the whole system?
What is the bleed procedure?
Do I need to get any O-rings or other parts before I start?
And, anything else that I forgot to ask???
Old 11-22-10, 02:59 PM
retired
retired's Avatar
Default AHC Rear Shocks
I have a 2001 LX 470..At 80,000 miles (four years ago) the fluid was low... I was told by the dealer that the rear shocks were leaking and the actuators valves needed to be replaced...The cost to repair was $595 for parts and $600 labor ($1195 total)...I had the car checked out by my mechanic....He informed me that I did not have a problem...the fluid in the tank was low due to normal wear and tear..This fact is also mentioned in the owners manual...I bought the fluid from the dealer and added about 12 ounces to bring it up to the normal level... The AHC takes a special fluid....I have 123,000 miles on it and the level is perfect.........I hope this helps...I would suggest you get your Lex on a lift and have it carefully inspected.........Have a great day.
Old 11-22-10, 03:44 PM
MNiern
MNiern's Avatar
I had it on a lift and the bottom of both rear shocks are covered in grease. Maybe I should take the new shocks back, clean the old ones, replace the ACH fluid in the tank and just keep an eye on the fluid level.
Have you seen the post about replacing the fluid and the improvement it makes to both ride and (ride) adjustment? https://www.clublexus.com/forums/lx4...-and-safe.html
Old 11-22-10, 04:48 PM
retired
retired's Avatar
When I thought I had leaking shocks, I priced them at AutoZone...I believe they were $40.00 each............Dont no if replacing AHC fluid will improve ride, but I believe in the old saying IF IT AINT BROKE DONT FIX IT...If your shocks are leaking, replacing might be a good idea...........Hope this helps...Last year my ignition cylinder jam snapped...Part $200 plus $400 labor...HAD TO B TOWED made of pot metal...VERY POOR >>should be a recall item, but it is not..........
Old 11-22-10, 05:42 PM
MNiern
MNiern's Avatar
The $40 shocks are for non-ACH systems. No aftermarket companies make replacements for the Toyota ACH shocks.
But I do think you are right about not fixing what ain't broke.
Ashron
LX - 3rd Gen (2008-2021)
06-18-16 03:47 AM
T4RBoarder
09-27-10 11:21 AM
mtwaters
08-24-07 04:24 PM
potterbiz
Maintenance
05-26-07 06:43 PM
TEECE
12-13-06 10:14 AM
Quick Reply: Replacing Rear ACH Shocks
