LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
Larger than stock tires?
Old 10-20-14, 02:55 PM
medici78
medici78's Avatar
Default Larger than stock tires?
Is anybody here running larger diameter tires? I am thinking of going to a 285/55/20 on
my 2008 LX570 but knowing how sensitive some vehicle sensors/electronics are, I wanted to know what others have experienced with this model. I know some folks have run 305/35/24 which are a little over 1" taller than stock and wanted to hear feedback. TIA
Old 11-04-14, 07:44 AM
NebulaLX
10th Gear
NebulaLX's Avatar
I am currently running 275/65r20 Cooper Zeon LTZs on my 2013. I have had only minor rubbing on the front mud flap (it protrudes a bit off the wheel well on my LX) when I am reversing and turning the wheel in the neutral height. Interesting enough, I have had no rubbing in my driveway when I lower it.
Old 11-05-14, 12:58 AM
medici78
medici78's Avatar
Thanks for the reply. Is there any noticeable difference in shift points? Did you recalibrate your gps and does that affect the speedometer readings, etc?
Old 11-17-14, 08:01 AM
NebulaLX
10th Gear
NebulaLX's Avatar
I am not sure about the shift points, because I only had the stock tires on for >1000 miles. But I have not noticed any difference, besides that they ride a little rougher (which was expected). The stock tires to me felt like riding on marshmallows, the all terrains feel a bit more proper and still is a more comfortable ride than any other vehicle on the road.
I did not have the speedo re-calibrated, but I am personally not very concerned with a change of a few MPH.
Old 11-17-14, 01:23 PM
Max707
Max707's Avatar
Wow, that's a 34" tire.
Old 11-19-14, 10:32 AM
NebulaLX
10th Gear
NebulaLX's Avatar
Typo on my part, I am running 275/60r20. I use to run 275/65s on my old tahoe.
Old 11-20-14, 12:47 PM
Max707
Max707's Avatar
Couple of questions? How do you like these tires with the AVS and AHC? The reason I ask is stock tires weigh 41 lbs, and these tires weigh 53 lbs. Just want to know how the LX handles that additional unsprung weight? Your the only owner I have found that has these big AT tires on a LX and I am looking at options so your input would be great. How long have you been running the larger tires? Any rubbing or negative?
Old 11-21-14, 06:13 AM
Headless
Headless's Avatar
I recently purchased a 2014 LX. I am also interested in putting larger tires on the LX. I was looking at either 285/55R20 or maybe 285/60R20 AT tires on.
For the mean time, I replace the stock Dunlop tires with the 285/50R20 Cooper Zeon LTZ tires I pulled off of my old vehicle before I sold it.
I actually think the ride is better with the Coopers on, and I like the look of the tires a lot more. I usually keep the AVS in the normal position.
I am looking at either the BFG AT K/02 (when the size is available) or the Goodyear All-Terrain Adventure with Kevlar. I had the Goodyear SilentArmor on an LR3 and absolutely loved them.
Old 11-21-14, 06:36 AM
Max707
Max707's Avatar
You and I are on the same track. Do you know what your 285/50R20's weigh? The BFG's are LT "D" rated tires that makes them really heavy. I would bet in this size around 58 lbs. That's 17 lbs over stock weight, a lot of additional unsprung weight. I want to know what that does to the ride and handling?
Old 11-21-14, 06:47 AM
Headless
Headless's Avatar
It looks like Amazon is putting the shipping weight of the 285/50R20 Zeon at 50lbs. Lighter than I would have expected.
Amazon.com: COOPER ZEON LTZ BW - P285/50R20XL 116S: Automotive Amazon.com: COOPER ZEON LTZ BW - P285/50R20XL 116S: Automotive
Old 11-21-14, 06:49 AM
Headless
Headless's Avatar
I also found on another forum where a guy weighed the 275/60R20 at 53lbs.
Old 11-28-14, 07:01 AM
Max707
Max707's Avatar
275/55/20 Dura techs weigh around 48 lbs. They are good looking tires. On another forum a guy that had the 60 series said he doubted I would be able to "see" a difference between "55" series and "60" series. Since I'm not going off road I will end up with either Bridgeston Alenza's in the stock size or the MicHelin LTX AT'S in 275/55/20 size.
Old 12-03-14, 05:29 AM
UpStarr
UpStarr's Avatar
22's I'd assume. Not sure of the tire specs, but worth looking at in my opinion. Pics courtesy of Park Place Lexus Plano Tx
Old 12-03-14, 07:40 AM
Max707
Max707's Avatar
I wimped out and ordered a set of stock 285/50/20 MicHelin Latitude 112V, designed for my LX570 and should be good for 40k miles rated for 55K miles. All reviews indicate great handling, quiet, on road tire.
Old 12-11-14, 01:37 PM
medici78
medici78's Avatar
Do you have pics of the Coopers on your LX? That's another option I'm considering, though I have my eye on the Toyo Open Country AT2 in 285/55/20, which is what prompted me to start the thread.
poorbong
GS F (2016-present)
27
04-04-21 07:09 PM
RogueRX
RX - 4th Gen (2016-2022)
17
04-16-20 08:31 PM
Neilchalas
05-15-18 07:34 AM
Jz39
IS F (2008-2014)
26
05-11-16 07:30 AM
Quick Reply: Larger than stock tires?
