LX - 3rd Gen (2008-2021) Posts related to the LX570 belong in this forum
How Do I Update the HDD
Old 08-20-09, 07:22 AM
jazz329
jazz329's Avatar
Default How Do I Update the HDD
HI, I have a lx 570 2008 usa I exported to Qatar so i need i map of Qatar .And Where is the HDD
I would like to now how to turn off the frout light in the mourning becase people say the light is on and horn
Old 08-21-09, 03:12 PM
AlMuhairi
AlMuhairi's Avatar
hello Jazz,
you would need a few things. For the map update, you need to buy the NAV update tool from one of lexus parts distributer, and you would need a map DVD (original), and a MAP key that only Lexus dealers here in the US have.
For the DRL, you would need the vectronix scan tool from the US to be able to customize the settings and turn off the DRL. But lexus does not support the scantool anymore and they use the techstream system which costs around $8000.
The navtool is worth around $1600, and the map key is around $400.
I was going to order everything but, didn't seem worth it to me.
let me know if you need more info.
Old 08-21-09, 03:38 PM
jazz329
jazz329's Avatar
hi
why do i nedd map dvd it is HARD DRIVE
Old 08-22-09, 02:36 AM
AlMuhairi
AlMuhairi's Avatar
You need the map dvd to load it on the navigation update tool using a computer, then you upload the map key to the navigation update tool, once you are done, you connect the navigation update tool to your car and then you can update the map on your navigation system. The Map key is only valid for one car.
The navigation update tool is the only way you can update the maps on the US-spec models.
Hope that helps
Old 08-25-09, 06:01 AM
Plucky
Plucky's Avatar
Hope that helps
Thanks AlMuhairi for the excellent info sharing . Sorry to jump in and ask if I have a Gulf spec LX570 and would like to update the Nav to latest 2010 version, would it still require the same procedure you mentioned , tools and price? And where can i purchase the update ? my prefrence is to really avoid the dealer serivce bill $$$
Thanks
Old 08-26-09, 02:52 AM
ige
ige's Avatar
Plucky, nop, just remove the older DVD Nav disc and replace it with an updated one.
Old 08-26-09, 10:31 AM
tigmd99
tigmd99's Avatar
There is no DVD to remove on the LX570...it is a hard-drive based NAVI.
Old 08-26-09, 02:34 PM
AlMuhairi
AlMuhairi's Avatar
tigmd99, the US spec LX570 is equipped with the HDD navigation system, but the LX570 in other regions are DVD based navigation systems.
For example, the Gulf-spec that Plucky and ige own uses a DVD navigation system
Old 09-20-09, 06:39 AM
Waasil
Waasil's Avatar
Dear Sirs,
I have imported a GS300 , of the year 2000, how can I update the navigation system from US to the gulf? does it require the same procedure as for Jazz?
What about the front lights which are always on, how can somebody switched them off?
Regards
Old 10-27-09, 12:44 AM
lexxtasy
lexxtasy's Avatar
Originally Posted by Waasil
Dear Sirs,
Regards
Why would you wanna do that, especially when everyone elses lights are off in your area...be different
Old 02-15-10, 03:52 PM
badralmana
badralmana's Avatar
hi dear
i can update ur lexus HDD NAVIGATION SYSTEM with GCC MAP for models 2007 till 2014
AND also i can reprogram DLR LIGHT with conversation radio and mileage
MY LOCATION IS IN KSA (IN ALHASA NEAR TO QATAR)
or in UAE
ALSO I HAVE 2014 MAP UPDATE FOR G.C.C LEXUS CAR
PLS email me badralmana at gmail.com
Old 10-06-10, 11:23 PM
lerdenebat
lerdenebat's Avatar
Default change the dvd does not works
hello Jazz,
Hi ,
I have LX570 from Meddle east and have navigation dvd in the front but i changed it for europe navigation dvd it does not works. How can i use that europe navigation dvd ? Please help. My car is 2010 new LX570
Old 02-07-13, 08:46 PM
badralmana
badralmana's Avatar
Originally Posted by badralmana
hi dear
i can update ur lexus HDD NAVIGATION SYSTEM with GCC MAP 2009
or in UAE
ALSO I HAVE 2009 -2010 MAP UPDATE FOR G.C.C LEXUS CAR
ThumperPup
ES - 5th Gen (2007-2012)
02-07-18 03:32 PM
maxse
GX - 1st Gen (2004-2009)
12-22-16 07:26 AM
lyxxsx1
14
05-11-09 08:13 PM
WhitBaby
10-16-08 11:17 AM
Quick Reply: How Do I Update the HDD
