LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Replacement Tires LX 470 '05
Old 07-11-16, 12:37 PM
RNoggie
RNoggie's Avatar
Default Replacement Tires LX 470 '05
I have a 05 LX470 that presently has 275/60R18 tires . I would like to replace them with a more aggressive tread pattern, however, can't find a tire I like in the same size. Can I go to a bigger/ wider or taller tire? Like a 285/60R18 or a 275/65R18. or do I have to stay with the original size? Any advice? Thx for the recommendation.
Old 07-12-16, 12:39 PM
toddmorr
toddmorr's Avatar
search. plenty of threads on bigger sizes that will fit. Your mentioned alternatives are pretty tame and shouldn't be a problem. Before I went that route though I'd check out any number of the websites that will calculate your speedometer error when you make the change. That bugs some folks a lot
Old 07-14-16, 10:51 AM
hankinid
hankinid's Avatar
Check the FAQ'q in the 100 series forum of ih8mud.com... http://forum.ih8mud.com/threads/100-...-trucks.30754/
Summary...you can fit up to 305-75's with a 16" wheel. I went about 1.5" higher with 285-75 16's...Toyo AT II's with zero issues after ~50K with rotations every 7500K. Tire store guy estimates another 10-15K easy.
No idea as to max size with 18" wheels...as was posted, simply check tire rack or similar for inflated diameter numbers.
Old 07-21-16, 04:12 PM
RNoggie
RNoggie's Avatar
Thanks for your info.
Old 07-21-16, 06:18 PM
hankinid
hankinid's Avatar
You're welcome.
jbobst
10-02-17 05:40 PM
jimc6391
05-17-14 07:58 AM
tritron
10-06-13 06:42 PM
snhrph
GX - 1st Gen (2003-2009)
02-05-09 07:23 PM
pemarsh
09-01-08 08:41 AM
Quick Reply: Replacement Tires LX 470 '05
