screeching noise
screeching noise
Intermittent screeching (extremely loud)noise when leaving a parking spot with the wheels turned..Sounds like from front? Any ideas? Noise did not change when applying brakes
check you power steering fluid level if it only happens when wheels are turned as thats when the system is loaded and if your short on fluid the pump will screech and eventually fail.
MoogieBoogie
Performance & Maintenance
13
08-04-06 07:39 PM
