presenting the DSRTWGN . . .
I bought this LX450 on a whim in the summer of 2013.
It came with just short of ~150K miles, factory lockers, and Supercharger and OME lift already installed. It also had an air lift system for towing and wiring for a satellite radio, both of which have since been removed.
then came the CB, a Uniden 520, and Firefly antenna, as recommended by the Firestick company owner himself
the tennis ball is on the antenna to prevent marks on the body when the antenna gets jerked around by tree branches or wind gusts
these things are heavy to begin with and gulp quite a bit already (the supercharger does not help in that department), so a few hundred pounds more will not make that much difference in cost of fuel for a truck that is not a daily driver
skid plates are not regularly needed as other areas typically make contact before the underbelly does, like the rocker panels, control arms, differentials - but typically, the good aftermarket sliders also come with protection for the catalyzers (which are expensive to replace)
encountered a check engine light: PO510 code "closed throttle position switch" - tested it according to the Factory Service Manual, switch has gone bad
installed a replacement pilfered from a Land Cruiser that is being parted out
got the light again two days later, same code - so another replacement was pilfered from a low-mileage rolled Land Cruiser yesterday - so far, the check engine light has not come back
