LX - 1st and 2nd Gen (1996-2007) Post here for topics related to the LX470 or LX450
Suspension Problem LX470 1998
Old 05-11-04, 11:16 PM
RonThompso
RonThompso's Avatar
Unhappy Suspension Problem LX470 1998
Recently the LX has developed a problem (or maybe 2 separate ones).
1) Frequently when I stop (street driving), the car drops, and then immediately jumps back to the correct height. Usually both back and front at the same time, but sometimes one after the other.
2) On some roads, the car becomes very bouncy, similar to a shock absorber problem, (front shocks were replaced 6 months ago).
One thought I had is that the suspension system is over pressurising, maybe due to a sticking valve, and then suddenly releasing and repressurising to the correct height.
Any ideas?
email ron.thompson@sumitomocorp.co.jp
Old 11-29-06, 01:19 PM
lx470man
lx470man's Avatar
ahh man i have the exact problem as you. It is eriee how exact your problems sounds like mine. I plan on chinging out the shocks, but is it really just the shocks? I mean the ride just drops all of a sudden. Also my lx470 feels like im riding a bull literally.
Old 11-29-06, 07:07 PM
B2001AS
B2001AS's Avatar
It's the time for the new suspension.
Go to sleeoffroad.com, get the OME 2" Lift
Old 11-29-06, 07:20 PM
RonThompso
RonThompso's Avatar
Default Don't think so...
Don't think it's shocks, as surely then the ride would be the same all the time.
I decided it was either a sticking valve in the suspension hydraulics, or a computer problem.
Never did solve it, and sold the car.
Hope you have more luck than me!
Ron
Old 11-29-06, 11:18 PM
Lexiss_sc430
Lexiss_sc430's Avatar
I had the same problem, here are some bits and pieces from the IH8MUD forums, It is almost one of the most helpful sites for your LX470.
Good information! Ben, just wanted to clear up something. You refer to "Accumulators" but do you really mean "Actuators" (Damping Force Actuator). See link below. Just don't want anybody to special order the wrong part.
I have read good things about Keith Bowers at B&B Suspensions. He rebuilds the actuators at a very reasonable price ($175/ea). You can reach him at: kebowers47@hotmail.com
http://forum.ih8mud.com/attachment.p...id=36919&stc=1
you are correct in that the whole assy is called the actuator. The piece I'm referring to is the big ball piece on the end of the actuator. This is the part that actually fails, it is the part that contains the nitrogen and the diaphragm. I have never seen the actual actuator fail, or one of the pumps for that matter.
Thanks for pointing that out.
Old 11-30-06, 06:40 AM
V8_Fan
V8_Fan's Avatar
Bad globes are the main reason for bounciness, but not why the vehicle would drop and change back to normal. You can perform the low-high AHC test and read the change in the number of gradations on the AHC resevoir. It should be at least 7. If less, the globes are bad. Globes go bad if you use the wrong fluid in the resevoir (must use Toyota AHC fluid, not hydraulic/brake fluid). The wrong fluid dissolves the membrane in the globes (I believe they cannot be recharged if this happens). Not changing the fluid collects excessive water in the system (just like brakes), and it could rust in the inside.
Is your car heavily loaded? There is a max weight tolerance (around 1200 lbs, including passengers) before the AHC reverts to low mode at all speeds. The AHC is one of the most often overlooked item in terms of maintenance, as not many people (even the service managers) understand it. The service manager at my dealer tried to tell me the height control unit was air actuated and could not be bled, and that only the 4 globes could be bled. Since I have the 2000 pages of factory manuals that tell you how to bleed them, I knew he was flat-out clueless. It seems most Lexus/Toyota service managers are clueless, so you gotta research what's really going on and specifically tell them what to do (ie, bleed 4 corner actuators plus the height accumulator).
Old 12-01-06, 11:02 AM
ctls
ctls's Avatar
I just went through the exact same scenario. It was the 4 accumulators, replaced them and has been great since. Keith Bowers did the rebuild and he guarantees them. Most people will tell you that the wrong fluid is the always the problem but the 900 psi nitrogen pad on the backside of the membrane bleeds over in to the SN10 oil naturally. Kinda depends on the quality of the membrane they used that day. There is a fifth accumulator for ride height but that almost never goes bad. If it does it is a pain to remove. The accumulators screw right off all you need is a open end wrench from Sears and grind it thin....
Old 06-21-07, 12:56 PM
chris231
chris231's Avatar
Does the 2"lift will keep the funtion of "height adjust"?
Old 06-23-07, 09:41 PM
V8_Fan
V8_Fan's Avatar
No. The only 2" lift that allows you to maintain normal AHC operation is the Keepslant lift. The key is you need to extend not only the AHC sensors, but the shocks using shock extension brackets and stabilizer extensions. The kit also comes w/ a longer rear lateral rod, since any lift will cause the rear axle to pivot forward. You also need to drop the front diff an inch (kit comes w/ a new IFS crossmember that lowers the diff).
BTW, I think the reason why the vehicle would drop as soon as you stopped, then raise back up, is the damper globe membranes were all shot (no nitrogen left). When you stop, the hydraulic pressure increases momentarily, but the membrane has no nitrogen on one side to absorb that increase, so the pressure exceeds the limit which causes the AHC to drop the vehicle into low as if you overloaded it. But after a few seconds, the pressure equalizes and falls below that limit and the AHC realizes it's too low and raises back to N.
Old 08-02-07, 01:28 PM
RXGS
RXGS's Avatar
how much do u think the dealer will charge to change the 4 atuators, because the ride is bouncy, but also, sometimes the truck has the front very low, and the back rly high, can this be resolved from new actulators?
Old 08-05-07, 05:17 PM
anngocvo
anngocvo's Avatar
Hi jmd93,
To change the actuators, the dealer will charge from $400 to $600 just to change one or all actuators. Front actuators is around 539 each and rear 586 each. This depend where you are. I changed this by myself and it is not that bad. It took me about 1 1/2 hours. I bought front and rear from Keith. http://yhst-76231485467161.stores.yahoo.net/
Old 08-05-07, 06:01 PM
RXGS
RXGS's Avatar
ok so bout 2 grand for those, how about for the sensors, how much do u think it will run all together, sorry for all the questions guys but im very thankful for all the help
Old 08-07-07, 10:46 AM
Hoser
Hoser's Avatar
Try removing, testing and cleaning the contacts on the AHC sensors first. They are known to get water in them and rust. Mark their position before removing.
Old 08-07-07, 01:48 PM
guitarmike
guitarmike's Avatar
Definitely need to replace the accumulators. This is a common problem with most LX470's. I have actually had some of my customers describe their car as riding like a pogo stick. Funny how the customer is right!!!. As far as the front lower than the rear, it sound as if one/all of your height control sensors may be rusted on the inside. If the vehicle has not been in a accident(thus resulting in bent height control sensors) it is very possible they are loosing connection at times on the inside. Highly reccomend having them looked at by lexus professionals, due to the fact that with our scan tool we can do a heck of a lot more diagnosis on the sensors.
Old 08-08-07, 02:55 PM
ihsmantx
ihsmantx's Avatar
I am having two problems one is when I stop at a drive through the car (2000 LX 470) the car raises and lowers back to N. The lady at the drive through get a charge out of it but I don't. It only happens sometimes. The other problem and my biggest concern in the VSC TRAC, VSC OFF and the engine light just came on and the car acts like it is starving for fuel at idle. When I step on it it smooths out until I let off the gas. Does anyone have a clue?
Quick Reply: Suspension Problem LX470 1998
