best way to black out my lexus
Kindly check your PM
No, it wasn't Die Cut, I cut everything myself. It was tough, but worth it.
I've gotta say, your LS looks stellar! Appears professionally done without a question! Excellent job...
Now..
As Road Frog stated...though I love everything you did..those halo's really had my attention..
If needbe, you can copy/past what you sent to Road Frog! If i'd do it im not sure, as im thinking theres alot to it. None the less your car looks great!
Now..
It's a lot of work. Requires removing the headlight assemblies and baking them to seperate the pieces before actually installing the angel eyes, Then ya gotta make double-sure it goes back together with no leaks, etc. Think I'll pass. I sure miss those from my 7 Series Beemer though.
I absolutely agree about the look of them on the 7 series!
For me, it's a toss up of which looks better:
The Audi LED's or the BMW halo!!
Now..
Now..
The halos areTRS RGB Led, color changing with remote. I also had a clear lens upgrade. Get compliments everywhere. People actually stop me to ask me where I bought them from, and have to tell them they are custom made.
One thing, I do have the AFS light on whenever i turn on the Headlights. I suspect the headlight was going faulty anyways, so I don't believe the halos affected them. The light won't come on until you actually turn the lights on. So I usually keep my halos and fogs on, so it doesn't bother me anyways. But the clear lens did give me a sharp cutoff.
I had my grill plastidip'd for a while. And it was fine until I wanted to refresh the look when I got the body kit. It was so hard to take off. In the tight areas it was a pain. Then the overspray on the under side of the grills needed to be cleaned off too. Those areas you don't see because most likely you sprayed just the top. I spent a few days using various chemicals to clean it. After all that I went ahead and had it painted when the kit was painted. MUCH better looking than the plastidip. Yeah you can't beat the price and I was all about the dip when k first put it out there to do it on the 460's but I've had a change if heart.
Dsmart
04-03-05 08:43 PM
