Ls460 Fog light relay
Hello,
Does anyone know where is the fog light relay located in the car? I have checked the fuse and the bulb everything is fine but it wont turn on. Could anyone here could give me some solutions.
1. Fog light fuse still good (even try to switch to new fuse) the fog light wont turn on at all.
2. Check the connection wire everything is in intact.
3. High beam still working fine using the stalk but fog light still not working. Yes, we can only use fog or high beam, but the issue is low beam and fog not even working.
4. Before the Fog light problem, the driver side fog light is blown. So I replace it with the new bulb. Everything is OEM part there are no after market part or HID .
5. This happen about a week after the driver side bulb blown then all sudden the fog just not working at all.
Please help me figuring out the issue since I have no clue what is wrong with the fog.
Thank you very much!
Yes, please somebody tell us. I went through this previously trying to find the relay to modify it. It could never be located, at least it's exact position on the car. And I tore fuse boxes off the car and looked under them, still couldn't locate it.
7milesout
7milesout
dis you solve it? I Have exactly the same issue on my Ls 460 2009
Hello,
