Did Discount Tire manager messing with me?
I've probably installed a thousand TPMS sensor rebuild kits. It makes sense to replace the kits when you get tires dismounted since you've already removed the tires and have access to the sensors. (Unless they are over charging for the kits). Regardless rubber grommets go bad like any other rubber part and should be replaced before there is an issue. It's just like replacing a rubber valve stem. Sounds like what someone else mentioned here is that they removed your sensors to avoid damaging them. (Rookie move) Any time you remove the sensor you are supposed to replace the rebuild kit.
I talked to a friend of mine who owns his own shop regarding this subject. He said he does have the tire sensor rebuild kits...he's only sold two of them in two years. Meanwhile he is stuck with this kit that he bought. He said it is similar in theory to replacing a regular valve stem when you get your tires replaced - that way it will limit the chance of a leak and a comeback. Problem is, to "rebuild" these sensors adds to the risk of damaging them...plus the new sensors have a rubber stem, rather than the older style aluminum body (no o ring to replace).
Personal opinions and the policies of large corporations may differ on this issue. Let's hear from someone who is knowledgeable about the policies of Costco, Walmart, DiscountTire and others.
I have watched Costco do these "sensor rebuilds" and they use a small torque to tighten the retainer nut. That leads me to believe that they are aware of the potential for damage due to over torqueing.
RocketGuy3
01-13-11 12:29 PM
