2008 460 replace engine oil warning light
I have 2008 LS 460 and replace engine oil warning light comes on every 3,000 miles. I plan on changing oil every 5,000 miles. How can I change warning to coincide? What are thoughts on changing every 7,500 if no pulling or hills? I am using synthetic Royal Purple. Is it worth the cost?
To change the mileage, it's in the "info > maintenance > oil" from the navigation screen. (i think that is it. something along that line. it's on the navigation for sure).
As for the miles to change the oil, every car is driven differently. I suggest you check the color per 3, 5, 7.5k miles and the color should tell you when is a good interval for yours.
lserlohn
RX - 1st Gen (1999-2003)
04-18-11 04:24 AM
