Test drive: what to look for or pay attention to ?
So, i will be making the move for my LS460L 2010 awd 85k miles next week before buying it.
What should i pay attention when test driving it, what kind of test should i do to verify different components of the car (suspension, wind noise...)
For the mechanic inspection, what should i tell the mechanic to focus on ?
thank you very much in advance and hope that all goes well
-Drive over some bumpy road and listen for hard rumbles in the suspension and body rattles.
-Safely take it up to 65-70 and brake hard, listen to and feel the brakes.
-From a standing stop do a very slow gradual acceleration. You shouldn't be able to tell the transmission is shifting without looking at the tach.
- From a standing stop accelerate very quickly. The shifts should happen rapidly and engine revs should not be excessive, i.e. staying in lower gear too long..
-Have mechanic check the control arm bushings.
-Check that the car was never in a flood.
Those are the only issues to worry about when looking for a good used 460?! Lol must be nice! Then again I guess these cars really are not old enough to have infamous famous and known problems unique to this model and the age of it. Try tracking down a nice 20+ year old Ls400! It's a royal ***** trying to find one that isn't shot to hell!
Literally test every single button/feature!! I picked mine up out of state..was looking forward to 700 mile drive home and realized there was an error with my radar cruise control...after I bought it! Had I known that day after the test drive, I could of had it fixed before I left, so I couldn't use cruise all the way home FTMFL!! TEST ALL BUTTONS!!! Test HVAC..test every damn thing..get the point? Good luck! !
Drive the car slowly (5mph) in a parking lot and brake gently. Listen for knocks, clunks, when the car stops and rocks slightly back and forth - bad control arm bushings or shock absorbers. Listen for a non-metallic clicking when applying the brakes - brake actuator. Drive on a smooth freeway and note any vibration at any speed from 30mph to 80mph - that could be a whole host of things from wheel balance (road force balance - relatively cheap and easy) to control arms/shocks/steering rack/wheel bearings (V expensive). And checks every switch and setting - it may take you a couple of hours but ANYTHING that goes wrong with the LS is expensive!
Check the service record too.
I have found it is a good idea to "Google" the VIN. Some very interesting information occasionally comes up.
I checked the carfax supplied by the dealer, everything is ok., no repairs, replacement done one time, oil change ok. I only found one recalls for the 2010: Recall ID # 86894 - STEERING:ELECTRIC POWER ASSIST SYSTEM
I will print this thread and test all the necessary. I remember when i bought the ES350, 15mins of test drive and its done, but the car has 34 000km.
I've already plan some $$$ for any upcoming repairs since i plan to keep it to the car's die, pray that it is as liable than my present ES350 2008.
