General braking question - possibly brake shim related?
Old 01-10-14, 12:44 AM
jimxms2
jimxms2's Avatar
Default General braking question - possibly brake shim related?
Guys,
I've been having an annoying issue with the brakes on my LS460 for the best part of a year now. Basically just before I come to a complete stop I get this creaking noise. I can feel it through the brake pedal and it almost seems like the brakes are grabbing at the rotors.
This is consistent with the fact that I don't seem to be able to come to an entirely smooth stop. I feel the brakes grab, I hear the creak and then the last 2-3mph instantly becomes 0mph resulting in an abrupt stop.
The noise also occurs when the car is in 'D' and I release the brake enough for it to creep forward slightly. Interestingly I can bring the car to a perfectly quiet stop at any speed if I engage 'N' before slowing down.
It started happening shortly after I bought the car, and as the rotors and pads were worn I decided to do the brake job myself. I purchased all OEM parts and used copper grease on the backs of the pads and shims, greased the sliding pins, cleaned everything properly. So a fairly decent job (i thought?).
The noise went away for about a week, but as soon as the cross hatching on the rotors had worn away, the issue returned.
As my LS has 140k miles I'm beginning to wonder whether it could be down to worn brake shims (or maybe even sliding pins)? To my knowledge these parts have never been replaced so if they are worn considerably maybe they are allowing too much movement?
Any ideas are greatly appreciated. I've tried several LS forums but as there aren't many LS460 DIY'ers, knowledge is limited.
Old 01-10-14, 06:32 AM
Received 2,501 Likes on 1,644 Posts
moving to right forum. gl.
Old 01-10-14, 06:36 AM
jimxms2
jimxms2's Avatar
Nooo I was hoping to get a more general insight as brakes are pretty much brakes regardless of model
Old 01-10-14, 09:27 AM
Devh
Devh's Avatar
It's very hard to diagnose based on your description because there are a lot of contradictory observations.
The things I would check are:
1. Brake actuator.
2. Get the brakes bled.
3. If its AWD It might be the source of the creaking when coming to a stop.
Old 01-10-14, 12:17 PM
1Putt
1Putt's Avatar
+1 on the comments above
Old 01-10-14, 12:58 PM
jimxms2
jimxms2's Avatar
1. Brake actuator.
Yeah I know what you mean. For every possible explanation there is something that contradicts it
1 . I do have the 'normal' brake actuator issues where it makes a bit of a 'windscreen wiper squeak' noise if you press the pedal down hard.
2. Next service in a week includes a brake fluid change so hopefully that will help.
3. Not AWD unfortunately.
I was just about to drop £200 on some new shims, fitting kit (clips..etc) and sliding pins. Should I hold off if none of these are likely to the the culprit?
Old 01-10-14, 01:19 PM
Devh
Devh's Avatar
If the problem was there before you did the brake service then it's most likely it's not the problem. The sliding pins need to be badly rusted out or gouged up to be the source of the squeak.
There are too many possibilities as it can also be a bad brake caliper or any of the above I mentioned. When you come to a dead end trying to find the source of the problem it then becomes wise to take it to a professional for diagnosis then trying to shotgun a solution by throwing parts at it.
Old 01-10-14, 02:38 PM
mmarshall's Avatar
Do you live in a region where it is often wet? (I see your heading includes the U.K, which generally fits that term).
When iron or steel brake rotors get damp or wet and sit for a little while, sometimes even for only a few minutes (such as after a rain or other wet weather, overnight dew, letting the car sit after driving through a puddle and splashing, or after hand-washing the car), they tend to get a thin coat of brownish-orange on them. When you first start up the car and go, the first couple of times you use the brakes, you'll often get some grinding noise and vibration exactly under the cirmcumstances you mention.....just before the actual stop. That is normal. That's because the brake pads are rubbing against the rust particles rather then on the rotor's smooth metal. The noise and vibration should go away after a few brake-pedal applications, as the coat of rust gets worn off....if it doesn't, then you may (?) have another problem and the brakes may need to be looked at.
Old 01-10-14, 03:15 PM
jimxms2
jimxms2's Avatar
Unfortunately its not that I've had this through summer and winter and have even tried a series of 70-10mph heavy brakes to clean everything up with no avail
Maybe I'll just have to bite the bullet and take it to a professional. I'll just kick myself if its something easily solved
Old 01-11-14, 08:00 AM
randomwalk
randomwalk's Avatar
The reason our brake is relatively good is because if more aggressive pad material thus the creaking. Also it's possible due to shims. I would take your brake apart and look for pad wear '& clean up the shim and apply anti squeak grease on back of the shims.
Brake actuator will make noise even when not moving. Brake fluid (bleeding) has nothing to do with noise.
Old 01-11-14, 01:07 PM
Devh
Devh's Avatar
It can have everything to do with noise. If there is trapped air in the system it can cause creaking at the ABS pump, master or at the brake caliper piston.
If you ever bled a hydraulic clutch you can get this sound emanating from the clutch master or slave. It's very common and sometimes the bubble will dissipate on its own or will need to be bleed out.
I have encountered this situation too many times.
mrjazz
05-24-15 03:30 PM
criticalgt
03-04-15 11:51 AM
ds13
Suspension and Brakes
06-09-14 04:50 AM
charris
05-02-10 04:41 AM
URDONE
07-09-07 09:32 AM
Quick Reply: General braking question - possibly brake shim related?
