Brake / Suspension Noises
When I apply the brakes on and off while in park, I hear a "fluttering squeaking" noise. I examined the brake pads and calipers, and everything seems to be fine. I greased up all the brake hardware and no luck.
Also, I have a popping noise while making turns while I am not braking. I really doubt there is any connection with the brakes? I recently went testing in a parking lot, and while slightly turning from left to right I noticed the popping constantly. Keep in mind no brakes were applied.
Last year the dealer replaced the brake actuator and all arms were replaced.
Anybody have similar issues they have dealt with, or knowledge to share? Please help as this is becoming a very annoying situation.
BTW, I am past my extended 100K warranty!!
I have some creaking issues too. I noticed mine happens when I'm driving slow through my garage. I took my car in the dealership because of the issue. Not sure what they did but heres a photo of the receipt.
I still have the same issues. Not sure if I should get it checked up before I install my coilovers. Wondering if the dealer would give me crap for it if I took it in after my suspension was installed.
These issues have been discussed at length here in the forum. Brake actuator could be the cause of clunking..easily heard with window down and backing up applying brakes..audible clunk or loud clicks. rattling up front could be control arms as mentioned or also loose pads in the calipers..happened to me, tension clips replaced (they were missing or broken due to rust), problem solved. On my 600, i had clunking..turned out to be control arms and my uppers were replaced for $2k under CPO warranty. Brake actuator issue is not a safety concern, but an annoyance type of situation. Does not indicate part is going to fail as I was told by two different Lexus techs
Umm, yes they most likely will..be prepared to fight is all I will say. Some dealers don't give folks a hard time about aftermarket stuff, but if you have coilovers and have issues going on with control arms or other suspension issues, I expect it to be challenged, especially if Lexus sends out an adjuster to oversee the claim. My mods are quickly reversable when it comes to showing up for warranty work..the adjuster already denied one of my tech's recommendations for replacing a suspension part because they couldn't "replicate the noise"..so I guess when it gets really bad and makes noise ALL the time, I will just bring it in then..my CPO is good through summer 2017 and I have a 2008
The only thing is that my control arms have been replaced with the brake actuator. I am sure that the bushings were changed out with arms?
More than worrying, its the point of driving a flagship Lexus and having to deal with non sense.
gadgetman1
Hybrid Technology
13
03-23-19 10:35 AM
mrjazz
05-24-15 03:30 PM
Baptizer
09-03-14 12:21 PM
