Engine Hesitation on 07 LS460
Old 02-10-13, 01:34 PM
XXLexusXX
XXLexusXX's Avatar
Franky I am taking it back to the dealer I bought it from and I am going to hand them the keys over as well, its a CPO vehicle but they should have fixed this problem during the 161 point inspection. I am going to just hand them the keys and go buy me a newer one with less miles on it, I don't want this headache especially after I just bought the car. I will keep you informed on what happens but I am going to keep in touch because I love your video and what you have done to your car.....Looks very nice......
Old 02-11-13, 04:39 PM
XXLexusXX
XXLexusXX's Avatar
Originally Posted by FrankyBoy
What you're saying is exactly 'one' of the problems I had. I had the 'lag' issue when the car would shift to 3rd and 4th gear and almost caused me to get hit when trying to pass. Not a good feeling at all! Definitely take it in to the shop ASAP!
Franky I took my vehicle back to the dealer and because of snowy roads they are keeping it until the next day. According to the tech, they have to duplicate the problem and get authorization from Lexus to reset the code. I am patiently waiting for good news that is. Hey Franky, what size tires do you have on your Lex? It appears to be staggered and I love the way it sits as well. Did you have something done to it to make it sit like that?
Old 08-10-13, 11:29 AM
newday95
newday95's Avatar
any idea how mucho this will cost ?????????????????????????
Old 08-10-13, 11:38 AM
jlawr
jlawr's Avatar
Just have this done:
File Type: pdf
Old 08-11-13, 04:19 PM
newday95
newday95's Avatar
can NYONE TELL ME HOW MUCH THIS WILL COST ?????????????????????????
Old 08-12-13, 02:36 PM
FrankyBoy
FrankyBoy's Avatar
I'm taking my car back into the shop tomorrow since I'm still having hesitation issues. Almost caused me to be in another accident yesterday and today! Not cool at all!
Old 08-12-13, 08:21 PM
Grouchy
Grouchy's Avatar
I noticed a bit of hesitation on my acceleration. I read up on the LS has a lot slower acceleration than other cars in the same class. I figured it was just in a higher gear. Is it just in D drive or is it the same when you manually lower the gears?
Old 08-12-13, 08:48 PM
I8ABMR
I8ABMR's Avatar
Sounds like ECU issue. There should be a simple reflash that needs to be done and this should be a thing of the past. My car had a shift delay at a light because apparently Lexus designed it to do that initially so save fuel. I complained and it was fixed easily. Your hesitation sounds like its far worse but generally these things are ECU.
Old 08-13-13, 06:22 PM
broken_tsi
broken_tsi's Avatar
Mine was fixed under CPO with a software update. Feels great!
DrQuality (08-05-21)
Old 08-13-13, 06:39 PM
Grouchy
Grouchy's Avatar
How long does it take?
Old 08-13-13, 08:08 PM
FrankyBoy
FrankyBoy's Avatar
The ECU was re-flashed the last time I took it for the same issue and the now hesitation has come back with a vengeance! I don't know the cause but they are looking into again as the tech's was able to see exactly what I was talking about when they test drove it today. I'll have to see what they say this time around.
Old 08-14-13, 10:41 PM
newday95
newday95's Avatar
i just hate itttttttttttttttttttttttttttttt
Old 08-15-13, 09:34 AM
broken_tsi
broken_tsi's Avatar
It took a day. I dropped it off in the morning and picked it up at the end of the day. They had some trouble with my battery being old though. I had to replace that at the same time.
Old 08-15-13, 03:47 PM
Fhobbs
Fhobbs's Avatar
I had the same thing. Had a reflash and it cleared it up, only to return at the next oil change. Last oil change I had Toyota dealer do it and it did not return. Some say it may be gas, but I have tried several different brands and cannot duplicat the problem due to gas. I don't know where to take for the next oil change coming up in 2k miles. Probably back to Toyota dealer but they do not report to the service record.
Old 08-19-13, 04:57 AM
RA032023
RA032023's Avatar
I have had this issue happen now three times, and each time it was after an oil and filter change! Absolutely no clue why this happens (2007 460 SWB), but the battery disconnect works every time.
Quick Reply: Engine Hesitation on 07 LS460
