Tire Pressure Display on Dash
Old 12-05-12, 03:16 PM
hillrnnr9
hillrnnr9's Avatar
Default Tire Pressure Display on Dash
Does anyone know which tire each of the tire pressure readings on the dash belong to? I have a 2007 LS460 and apparently had a nail in a tire that was slowly losing air. It took a bit of extra time to test each tire to discover the culprit. The dash displays tire pressure readings (1-5 including the spare) for each tire's PSI. Please let me know if anyone knows the corelating tire for each reading (1-5). i checked the manual and it was not clear which reading position went to which tire. Thanks!
Old 12-05-12, 03:34 PM
rominl
exclusive matchup
rominl's Avatar
there is no particular ordering, you just have to try. it will stay the same order, but say you rotate tires later, it's all changed again
Old 12-05-12, 03:37 PM
hillrnnr9
hillrnnr9's Avatar
is it safe to assume the one reading that does not change (as you drive) is the spare?
Old 12-05-12, 03:47 PM
ElliotB
ElliotB's Avatar
This old thread will answer your question:
https://www.clublexus.com/forums/ls4...s-display.html
Old 12-05-12, 03:50 PM
jmcraney
jmcraney's Avatar
Yes! Yes! Yes!
Old 12-05-12, 04:02 PM
CJITTY
CJITTY's Avatar
Preach preach searches ftw
Kuhn
10-25-22 10:56 AM
propcop
Northeast
04-05-18 10:22 AM
Redeemed07
03-09-18 02:31 PM
paprgypc
Hybrid Technology
03-20-17 10:25 AM
ikeb
01-03-11 10:18 PM
Quick Reply: Tire Pressure Display on Dash
