Starting engine without foot on brake pedal
Old 02-05-10, 09:11 AM
jstjohnz
jstjohnz's Avatar
Default Starting engine without foot on brake pedal
Requiring that the brake pedal be depressed in order to start the engine can be a nuisance, say if the driver is out of the vehicle and the passenger wants to start the engine to run the A/C, etc.
There is a workaround though. Press the engine start switch once to go into ACC mode, then press and hold it for 15 seconds and the engine will start without the brake pedal having to be pressed.
Old 02-05-10, 10:25 AM
OPSBD
OPSBD's Avatar
There has been a few times when I was in the pass seat and wife turn off the car to go to the store and it started getting hot inside and needed AC. I had to get out, walk to the driver seat, press the break and start the engine. I tried as you said and it works!!! Very interesting. Thanks for sharing!
Old 02-05-10, 10:29 AM
rominl
exclusive matchup
rominl's Avatar
that's one nice trick, thanks for sharing!
Old 02-05-10, 11:09 AM
dimapb
dimapb's Avatar
Wow!!! Thank you!!!
Old 02-05-10, 11:12 AM
AceVA
AceVA's Avatar
Neat, thanks!
Old 02-05-10, 01:00 PM
Nospinzone
Nospinzone's Avatar
There has been a few times when I was in the pass seat and wife turn off the car to go to the store .......
Well that's a real problem right there. NEVER allow your wife to go into a store!
Old 02-05-10, 09:17 PM
jlawr
jlawr's Avatar
So if your wife leaves the car and takes her purse with the key fob in it, you can still start the car from the passenger seat?
I hope not!
Old 02-05-10, 09:29 PM
jstjohnz
jstjohnz's Avatar
I hope not!
Yes, but only if you have your key fob. It only eliminates the need to press on the brake pedal when starting.
Old 02-06-10, 09:29 AM
Mike_TX
Mike_TX's Avatar
I hope not!
Only on cars with black interiors.
Old 02-06-10, 10:06 AM
zzzzdoc
zzzzdoc's Avatar
Whew! What a relief!
Neat trick, thanks for sharing.
Old 02-10-10, 12:05 PM
tennisstar
tennisstar's Avatar
ooh thanks for sharing the neat trick....
Old 02-10-10, 05:00 PM
davedan
davedan's Avatar
Default start engine without foot on pedal
can not do on my 09 ls awd swb
Old 02-10-10, 05:41 PM
jstjohnz
jstjohnz's Avatar
It should work on your car. You start from the ignition off position (no lights on dash display). Press and release the start button once, this gets you into ACCY mode. Then press and hold the start button, and the engine will crank after about 15 seconds. You have to be in ACCY mode, not OFF or IGN mode, when you do the press and hold.
Old 02-11-10, 11:19 PM
encore888
encore888's Avatar
Neat! I never knew that, although a lot of us are now well aware of the 3-second emergency stop.
Old 02-12-10, 12:10 AM
uae
uae's Avatar
Thanx it worked on my LS 460 & LX 570
Quick Reply: Starting engine without foot on brake pedal
