Notched my rear subframe to fit wider wheels.
Old 05-25-15, 11:46 AM
lildann
lildann's Avatar
Default Notched my rear subframe to fit wider wheels.
Just thought I'd share another way to fit wheels. I wanted to run my brother-in-law's VIP Modular wheels. The offset was a little aggressive in the rear. I have all the Megan arms in the rear but didn't want to run crazy camber like -7 or anything. Brownman said he had heard of people in Japan notching their subframe, so I tried it. Basically I removed the upper control arms in the rear and used an air powered, mini grinder to cut the holes bigger. I cut them in towards the center of the car and used the marks for the oversized washer as a template of where to cut. It worked great as I can now tuck more aggressive, 11" wide rear wheels. I've since changed my wheels and they also tuck. I'm running -4.2 degrees camber. Here's some pics. I had more pics but I broke my phone and lost them.
This is the first one I notched. Not the best but it worked. The rest are cut better.
Here is before and after pics if the rear. Moved the wheel in so I could tuck.
My new wheels. 20x11 +27
Old 05-25-15, 11:54 AM
KING
KING's Avatar
Looks good.
But any pics of where you touched the sub frame?
Does still ride okay?
Old 05-25-15, 03:12 PM
lildann
lildann's Avatar
Originally Posted by tHeKiNg911
Looks good.
The top pic is the subframe where the upper control arm goes in. It rides fine. Can't tell a difference.
Old 05-25-15, 03:20 PM
2KHarrier
2KHarrier's Avatar
I did this a few years ago on my 1980 Chevy Malibu (full frame car), but I can't say I've heard of someone doing it to a car with a Unibody.... Good work!
Old 05-25-15, 03:22 PM
lildann
lildann's Avatar
Thanks! I appreciate it!
Old 05-25-15, 07:46 PM
LiCelsior
Retired
LiCelsior's Avatar
nice job, i should have done this with the Waffe's.
Old 05-25-15, 07:49 PM
lildann
lildann's Avatar
Thanks. What are the specs on your wheels.
Old 05-27-15, 11:56 AM
HiloDB1
HiloDB1's Avatar
Personally I wouldnt do this mod. There is nothing besides the friction of the bolt keeping the arm from sliding around in that slot. I would get a cam bolt and weld on some positioning stops like the toe arms have to lock it in position.
Old 05-27-15, 01:00 PM
Robles84
Robles84's Avatar
Looking clean.... how long did it take? How hard is it? I'm intermediate when it comes to diy projects.
Also what suspension do you have? Springs coilovers or bags
Old 05-28-15, 06:00 AM
lildann
lildann's Avatar
I was a little worried about doing it too. But, after looking at it, I knew it would work. It locks in the same way that it does from the factory. The arms are held by the bolt and by the subframe pinched in on them. I only cut in towards the center. Worst that could happen is it gets me max negative camber.
Old 05-28-15, 06:06 AM
lildann
lildann's Avatar
It took about half a day and about 7 carbide bits. It's not that hard but it is tedious. The hardest part was that the bit wanted to jump around and then it would break. It may be something you could do but be careful. If you mess something up, you will have your upper control arms out. Also, the only way to undo it is to replace the rear subframe. I'm bagged on airlift struts and V2 management.
Old 05-21-17, 09:28 PM
Robles84
Robles84's Avatar
How is it holding up still? Yup date please
Old 05-22-17, 09:26 AM
lildann
lildann's Avatar
Still have holding up fine. I don't drive it every day but I've had no problems so far.
cuongdaddy
07-03-17 10:10 AM
sojah
VIP Style
03-22-16 07:23 PM
bigl93
Suspension
09-27-15 09:57 PM
Galvez
02-15-14 12:04 AM
randee973
02-09-12 07:23 PM
Quick Reply: Notched my rear subframe to fit wider wheels.
