2001 radiator fans come on, but car won't start
Hi Group;
My wife took her '01 LS430 out for errands this a.m. Upon her return, after about 30 min,.went to back it further into the garage, radiator fans engage with the ignition switch in the "on" position (full dash displays), but when turned to crank...nothing. Battery is less than two months old, terminals clean.. thoughts? That dang starter?
Another thing to try... You can try cycling the shifter through all the gears, and then crank again. There's a switch at the transmission that only allow the starter to engage when the shifter is in "P" or "N". You may have a loose, disconnected, or defective switch.
Thanks!
I did try to jump it..No joy.. I will try the cycle thru the shift positions today. Will try it all before getting it towed to the shop, and get that inevitable $700+ starter replacement diagnosis..
I would first try putting the shifter in "P" or "N", foot on brake, then crank to see if the starter engages (click). If not, take a look at the starter relay per the procedure below...
Eds98LS
16
01-20-16 01:00 PM
