Seat Heaters take a little while to get warm?
Old 01-08-15, 02:34 PM
arcteryx
arcteryx's Avatar
Default Seat Heaters take a little while to get warm?
With this cold wave most of us are feeling, I have been using the seat heaters some. It seems that the fronts take a few minutes, maybe 5 or more, to get going. They do get warm though so the wiring is intact. Conversely, the ones in my Excursion take about a minute. Is this normal and are others seeing this?
Old 01-08-15, 03:58 PM
campisi
campisi's Avatar
Yes I see this as well on my 03. They take a while before you can feel anything and even then they never really get very warm at all. In contrast to my 11 Subaru's seat heaters they really suck.
Old 01-08-15, 05:30 PM
Lavrishevo
Lavrishevo's Avatar
My 04 does not heat up very fast but I can only take the 1st or 2nd setting on heat. Sets my butt on fire on the hottest setting. Most likely your seat cushion is not allowing the heat through.
Old 01-08-15, 06:29 PM
randal
randal's Avatar
I find that my seats heat within a couple of minutes. The LS heater elements are really top quality. They use a "woven" element design which is far superior to other cars which typically use just a couple of "zig-zag" elements. The Lexus design provides more even heat to the buttocks and back area.
Here is a link to the thermal picture of my 02 LS430 taken with a Fluke IR camera. It shows the woven elements.(click on the picture to enlarge) -> http://us.lexusownersclub.com/forums...eated+%2Bseats
Old 01-08-15, 06:38 PM
2KHarrier
2KHarrier's Avatar
Nice photos Randal.. Mine heat up kinda slowly... The RX heats up a little quicker than the LS, but the coverage is better on the LS ( great Infrared photos...)
Old 01-08-15, 07:59 PM
arcteryx
arcteryx's Avatar
Wow, those photos are cool!
I need to order a new ds lower cushion, more than 30 minutes and I start getting uncomfortable, The right side where the seam is is very hard. So hopefully the heating elements will be work a little better too.
Old 01-09-15, 12:21 AM
warminwisc
warminwisc's Avatar
Mine stink takes 15 minutes than i do not need em.
Old 01-09-15, 12:26 AM
Ce3kay
Ce3kay's Avatar
that's weird my driver side is slow also, takes 3-5 mins to get warm as my passenger side takes about a min top and its on fire!
Old 01-09-15, 06:31 AM
Lavrishevo
Lavrishevo's Avatar
It actually makes perfect sense. If the seat cushion is deteriorating it will prevent the heat from reaching the top of the cushion and out the leather. Drivers seat would obviously be the first to go. Even my rear seat heaters work well. I would consider replacing the bottom seat cushion.
Old 01-09-15, 06:35 AM
Tom57
Tom57's Avatar
It depends on model year and features of your LS. My '01 heats up very quickly and uniformly, but it doesn't have seat coolers. The seat heat dial on the '01 is a wide-range dial as well. My '06 is slower to warm up and, of course, with cooled seats, the dial is only about half the range of the '01, since 1/2 the dial is for heat and the other half is for cool adjustments.
Old 01-10-15, 09:36 AM
arcteryx
arcteryx's Avatar
My kids have confirmed the rears heat up very fast/well, so I think it is due to the cushion.
For the cushion, do they sell they cushion with the wiring? Or do you have to reuse your existing? When I replaced my Fords', the wiring was already on the pad, so it was plug n play.
Old 01-10-15, 10:03 AM
LiCelsior
Retired
LiCelsior's Avatar
haha thats pretty cool, always wondered how much coverage there was. My driver front seat is pretty slow also, but it is probably due to wear.
Old 01-10-15, 10:34 AM
Lavrishevo
Lavrishevo's Avatar
Couple more links. Look at the notes for 71511S and notes for N1*
04 - 06
http://www.lexussouthatlantaparts.co...seat%20cushion
https://www.clublexus.com/forums/ls4...for-ls430.html
Attached Thumbnails Seat Heaters take a little while to get warm?-713912.jpg
Old 01-10-15, 05:28 PM
randal
randal's Avatar
In contrast to the LS, take a look at this thermal pic of a 2011 Honda Pilots' heated seats.
Notice the gaps in the elements leaving cold spots. Notice that the passenger side back is not even heated though the drivers side is. What in the world was Honda thinking?(hint:cheap).
Big difference from the LS which has very nice and even coverage (the woven design).
Attached Thumbnails Seat Heaters take a little while to get warm?-2011pilot.jpg
SuperCoupe400
02-01-22 08:06 PM
Jess21
10-28-14 01:23 PM
Black94RX-7TT
SC- 1st Gen (1992-2000)
16
05-08-14 10:47 PM
grottoman
01-31-12 05:06 PM
Trouble-T
12-06-09 04:33 PM
Quick Reply: Seat Heaters take a little while to get warm?
