Biggest Spacer without changing studs
Old 08-27-14, 11:03 AM
jdotlim
jdotlim's Avatar
Default Biggest Spacer without changing studs
What is the biggest spacer anyone has ran and did not have to change the studs out?
Old 08-27-14, 11:20 AM
LiCelsior
Retired
LiCelsior's Avatar
i would say 5mm would be the max, but even then thats already pushing it.
Old 08-27-14, 11:23 AM
jdotlim
jdotlim's Avatar
thanks, appreciate it.
Old 08-27-14, 12:04 PM
j stuff
j stuff's Avatar
agree with 5mm.
Old 08-27-14, 12:48 PM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
5mm is the biggest I would go.
There are spacers with studs built in but I don't know how safe they are. I'd imagine anything under 20mm should be alright with this type of spacer.
Old 08-27-14, 04:37 PM
rkw77080
rkw77080's Avatar
I've installed 10mm spacers for the front without replacing the studs. For proper and easy alignment, I glued the spacer to the back of the wheel, and I used new lug nuts with longer shaft. Just make sure the spacers you get have large enough holes for the lug nut shaft diameter.
Old 08-28-14, 03:27 PM
jdotlim
jdotlim's Avatar
i was thinking 10mm might work, i do have aftermarket lug nuts that is longer than oem. i will give it a try to see how tight it is before replacing the studs. Thanks for the help.
Old 08-28-14, 06:50 PM
rkw77080
rkw77080's Avatar
To be safe, I’d do a dry-fit with the spacer stacked against the wheel, and insert a lug nut to see how far in it gets. Ideally, the lug nut should reach within ¼” to the surface (see picture). The stock studs are about 1” long and you’d want to get about ¾” of it into the lug nut.
Old 08-29-14, 06:16 AM
wuznme
wuznme's Avatar
I ran 15mm front and 25mm rear with out issues for 2 years. These were the ones with studs as someone mentioned.
Old 08-29-14, 08:12 AM
j stuff
j stuff's Avatar
I think OP is asking only about spacers without attached studs.
I was a believer with spacers for years. Always had project Kics spacers until one failed on me with a stud breaking off.
I pretty much wont be using spacers anymore.
JDW379
01-30-14 04:53 PM
OneJay
Wheels, Tires & Brakes Forum
09-21-10 10:41 AM
pizdets17
10-26-09 09:21 PM
Infamous 1
05-01-09 09:31 AM
3rdelement
02-25-06 10:18 AM
Quick Reply: Biggest Spacer without changing studs
