Automatic Door closer failed
Anyone know how much this should cost me to fix? I think the motor is dead.
THx
THx
Now there are fewer UL and CL than ML and others but I have heard few issues with the door closers. at 600 bucks I would be thinking boneyard for a used part. Prolly little demand so price might be pretty low.
If you would like to DIY, the job is not too difficult. There are good threads on taking the door apart enough to change out the closer. If it is only the motor within the closer assembly at fault, the part (new motor) is under $15 on flea-bay, but will require a bit of surgery with a Dremel tool or file to modify the shaft.
swat1727
08-11-08 01:26 AM
