Blinking AFS Light
Old 02-12-13, 06:56 AM
warminwisc
warminwisc's Avatar
Default Blinking AFS Light
Ok this bad boy is blinking like a lighthouse on roids. Adaptive Front Steering? Anyone have this occur and can shed some light on the subject? Thanks Warm
I recently drove thru a pretty good slush ice storm
Old 02-12-13, 09:23 AM
chrispy
chrispy's Avatar
Adaptive from lighting system. The sensors are located on the lower control arms I believe. Maybe they got damaged. Do your headlights still turn when you turn?
Old 02-12-13, 09:33 AM
warminwisc
warminwisc's Avatar
I will check tonight, I guess there are some height sensors as you speak. Parts.com is 240 otherwise 400 hun from lexus. Will a Vag Com easily pick up the problem, does it have to nbe a Lexus Vag Com. Off to the car wash to see if somethign is gummed up from all the ice slush but i guess the bracket can break. Another lovely plus for living in the midwest
Old 02-12-13, 04:36 PM
TaninAuto
Sponsor
TaninAuto's Avatar
Probably the left rear sensor that's bad. You will see it on the control arm towards the middle of the car if you look under the driver wheel.
Mine did the same thing.
__________________
TANIN AUTO ELECTRONIX
262-456-4147
contact@taninauto.com
www.taninautoelectronix.com
Old 02-12-13, 07:25 PM
tcbted
tcbted's Avatar
When my left rear sensor went bad, my headlights defaulted to a very low position.
Years of snow and slush corroded the connection
Old 02-12-13, 10:22 PM
warminwisc
warminwisc's Avatar
was it the rear? CAn you teel by looking the bearing and bracket are a mess?
Old 02-15-13, 06:08 AM
newday95
newday95's Avatar
how many are they in a 2004 ????????????????????
Old 02-16-13, 06:26 PM
SkipABeat
SkipABeat's Avatar
My 2004 LS430 had about 30k miles on the odometer when the AFS started flashing. Many with the same problem pointed out the two ride height sensors on the front and aft driver side so I decided to check them out.
The sensors and the moving parts were all rusty from the salt from many winters. So I cleaned them and applied CorrosionX on the areas that move with the axle. The problem went away and the headlight aim became normal again. It was very low when the AFS was flashing. This happened a year ago.
I thought i'd give It a try before I spent money on the pricey parts. It's worth giving it a shot.
Old 04-23-13, 04:40 AM
warminwisc
warminwisc's Avatar
www.parts.com
89407-50060
89408-50060
287 bucks for sensors
Old 07-02-13, 10:00 AM
stvincent
stvincent's Avatar
thx. i will try this first before jumping on new parts. i suspect it's the one on the driver side rear control arm? hopefully this will take care of the problem..
mine has 80k miles though..
Old 01-14-14, 04:51 AM
warminwisc
warminwisc's Avatar
This may be an answer to your broken levelng sensor.
Old 07-28-14, 01:02 PM
bconway1
4th Gear
bconway1's Avatar
Default Rear sensor corrosion
I had the blinking/flashing afs light. The car is a 2004 LS430. I took apart the rear sensor and did exactly what it says in the attached thread. No problem in months of use.
One or more of the springs may be corroded beyond use. Use a copper spring not a metal pen spring. I bent a piece of copper wire. Saved me $3-400 for a rear sensor.
http://www.sector13.org/jason/prius/...ghtsensor.html
Old 11-13-16, 01:56 PM
bmore430
bmore430's Avatar
This was helpful although my sensor was too corroded inside to be saved. same issue with the springs being rotted out.
Bluv
02-14-16 01:20 PM
gregskiii
12-04-14 07:55 AM
LADavidGS
04-12-14 11:06 AM
LTDQTY
11-22-10 05:30 PM
lexgs350
01-18-08 06:52 AM
Quick Reply: Blinking AFS Light
