06 LS430 feels sluggish 80k miles
the air filter was a little dirty but he said it was replaced not too long ago. i cleaned it out for him and change the plugs. not sure if its to normal specs but does feel better then before.
NOW im trying to fix the door handle unlock button. im not sure what it is called since i dont have a baller car. lol he said before sometimes it would work but now it doesnt work at all. he replaced the battery on the key, but still nothing.
Does it have to be reprogrammed? or
is there a fuse for it? i looked in the fuse panelss and didnt see anything,
thanks
thanks
First thing I would do is clean my fuel system. Run a bottle of techron through. And maybe on the tank after that, a dose of lucas upper cylinder lubricant/injector cleaner.
Air filter should be checked or replaced.
If those things don't fix it, you could always do a full tune up including spark plugs.
The button on the door handle is to lock the door (if you have the smart access key in your pocket). You grab the inside of the door handle to unlock the door. The smart access power button under the dash, above the driver's knee, must not be off.
