should i be worried
Old 06-04-11, 08:05 PM
ray123
ray123's Avatar
Default should i be worried
i saw this message today when i turn on my car,im a couple mile over due on my oil change may this cause this error messager..excuse my dust..lmao
Old 06-04-11, 08:44 PM
CarGuy89
CarGuy89's Avatar
That light comes on every 5k mi to remind you to get the car serviced. There's nothing actually wrong with it.
Btw, how do you get the compass to display on the lower center? I can only seem to get the outside temp there.
Old 06-04-11, 09:01 PM
ray123
ray123's Avatar
I think it the disp 2 on the steering wheel but my does not seam to wrk the compass won't Change for me either
Old 06-04-11, 09:06 PM
BC Rider
BC Rider's Avatar
Fwiw - If you have Nav you don't get the compass.
Old 06-04-11, 09:39 PM
ray123
ray123's Avatar
No wonder. I dnt have nav
Old 06-04-11, 10:26 PM
CarGuy89
CarGuy89's Avatar
Thanks for the info. I guess you could figure it out by looking at the screen, but it would be much faster to see it right in front of me. That and I already have outside temp on my center console.
Old 06-07-11, 03:23 AM
fergo308
fergo308's Avatar
It does seem odd to have two lots of outside temp display on the one dashboard. I've often wondered why that part of the cluster isn't adjustable.
Display 2 only seems to change the size of the vehicle display on my radar nav setting. I've not yet found any other use for that switch.
Justin...
Old 06-07-11, 04:13 AM
Muti007
Muti007's Avatar
Justin...
How do you change the size of the vehicle on the NAv screen? My disp2 only turns the temp on the dash on and off, nothing else.
Old 06-07-11, 05:52 AM
Stu
Stu's Avatar
Reset Maintenance Required Light
1. With your car OFF, place your key in the ignition and turn to ""On"". Do not start the car.
2. Find the odometer button and press until it reads the total odometer setting, (not the Trip A or Trip B setting).
3. Turn the key to OFF.
4. Place your finger back on the odometer button, press and hold. At the same time, turn the key back to ""On"".
5. Hold the odometer button in until the MAINT REQ light goes out...should take about 8-10 seconds.
Old 06-07-11, 11:03 PM
fergo308
fergo308's Avatar
You can't,you can only change the zoom on the map on the navi screen.
As for the size of the vehicle display on the radar cruise display,that you can change using the disp2 button,but it has no other effect than making the picture bigger or smaller as far as I've seen so far.
Justin...
Old 06-08-11, 06:37 AM
caddyowner
caddyowner's Avatar
Justin...
Are you referring to the button and display that changes the sensitivity / following distance of the laser / radar adaptive cruise control? If so, that works on may car to allow you more or less cushion between you and the car in front.
Old 06-08-11, 07:47 AM
thinkin
thinkin's Avatar
lol - I was thinking the same thing. That "size of the car" is the following distance!
Old 06-09-11, 04:01 AM
fergo308
fergo308's Avatar
I use it so rarely,I haven't checked that. Thinking about it,that makes perfect sense,the 'bigger car' image would be a closer buffer.
I've just learned something,cheers guys!
Justin...
Old 06-09-11, 04:28 AM
caddyowner
caddyowner's Avatar
I use the laser cruise daily as my freeway commute is against the heavier flow of traffic.
Old 06-09-11, 08:27 AM
jayclapp
jayclapp's Avatar
Agree. I find the laser cruise is perfect for heavy freeway traffic. I realize that most people would think this was crazy, but it actually is a great help once you get used to it. When I drive a loaner without it, I am nearly lost in driving with a normal cruise.
Quick Reply: should i be worried
