Driver seat is rocking when i break..
Old 11-29-10, 04:10 PM
03 LS 430
03 LS 430's Avatar
Default Driver seat is rocking when i break..
hello everyone i notice today when i was coming home from work that my seat has movment when i go to break..so i gets out the car to see whats the problem by pulling on the back of the seat and notice theres alot of back and forth play threw out the whole seat..i understand it a unit..but i dont understand how theres so much play in the seat..something must of came loose..im open for any suggestings on how to rectafiy the situation
Old 11-29-10, 07:47 PM
StanVanDam
StanVanDam's Avatar
The 4 front seat mounting bolts should be torqued to 27 ft.lb (37 Nm). The other components and their torque specs are in the attached diagram.
EDIT: The forum software shrunk my full diagram and made it small and hard to read. Go here for the full-sized front seat component diagram - http://img716.imageshack.us/img716/9...components.jpg
Attached Thumbnails Driver seat is rocking when i break..-frontseatbolts.jpg
Last edited by StanVanDam; 10-24-11 at 01:03 PM. Reason: Added link to full-size diagram
Old 12-01-10, 04:00 PM
03 LS 430
03 LS 430's Avatar
omg..lol..frist of all thanks for the images how to read it another..i was informed that the front power seat adjuster has be come weak due to me being so tall and heavy..275lbs with me putting constant pressure on the back seat with the stop and go play has becoe a factor...the dealer wants 1500.00 for only the seat adjuster and thats crazy dont got money for that..so iam going to try to fix it but don know where to begin.by the way i check the bolts and they are tight..thanks
Old 12-01-10, 04:54 PM
Jabberwock
Jabberwock's Avatar
Hit <control>+ on your keyboard about 10 times that will make it large enough to see it in great detail.
Old 12-01-10, 05:09 PM
CarGuy89
CarGuy89's Avatar
^Lol very true. Doesn't help that I have 1920x1080 res, everything is so much smaller than on my previous laptops. Just for fun, 'control'+'-' makes everything really small (zooms out). It went to the point where I couldn't read the anything on the screen anymore
Old 12-02-10, 04:51 AM
Jabberwock
Jabberwock's Avatar
I guess it also helps to use a 27 inch monitor : )
Old 12-02-10, 05:02 AM
caddyowner
caddyowner's Avatar
This is when my iPad comes in handy.
Old 12-02-10, 07:23 AM
Bigfella
Bigfella's Avatar
I had the same problem happen. My local non Lexus mechanic gave me the option of $1500 to replace part or weld it for $100. Seat height adjust would then be disabled. We set the height where I liked it and then welded it place. No problems since.
Old 12-02-10, 07:47 AM
StanVanDam
StanVanDam's Avatar
The square in the bottom left tells you how to read the numbers. The first number is the torque spec in Newton*Meters, then in brackets are the equivalent kgf*cm and ft*lbf numbers. Note that some numbers are measured in inch*pounds so adjust accordingly.
Old 10-02-11, 08:03 PM
Jerryw74
Jerryw74's Avatar
I have the same problem. Do they sell the seat adjustor separately?
Old 10-19-11, 07:16 PM
Jerryw74
Jerryw74's Avatar
I took the side of the seat apart and it's a metal bracket that is broken. I'm going to try and get it welded. I will post pics once I get the part fixed.
Old 10-24-11, 01:05 PM
StanVanDam
StanVanDam's Avatar
Full-sized front seat component diagram here - http://img716.imageshack.us/img716/9...components.jpg
I didn't notice that the forum software resized my picture when I uploaded it, which is why some of you found it difficult to read.
Old 08-31-13, 06:59 PM
PearLS430
PearLS430's Avatar
So did u ever post pictures of your bracket welded?
Old 01-02-23, 03:35 PM
Tom1978lex
3rd Gear
Tom1978lex's Avatar
Default Ls430 seat rocks
Hello I have an 06 lexus ls430 and the seat rocks a bit. I have the seat out now. Can someone tell me what damaged part I’m looking for ? Or an on line part I can order for repair? Tks
Ericspyder
01-29-18 03:43 PM
nuraman00
ES - 6th Gen (2013-2018)
02-14-17 07:04 PM
LexusLadi
04-09-15 01:32 PM
AlblineLex
IS - 1st Gen (2001-2005)
02-05-14 01:42 AM
UnSub
10-10-11 05:57 AM
Quick Reply: Driver seat is rocking when i break..
