'05 LS430 Telescopic Steering Wheel Won't Move In/Out Retract/Extend
Old 10-24-10, 03:31 PM
Viged
Viged's Avatar
Exclamation '05 LS430 Telescopic Steering Wheel Won't Move In/Out Retract/Extend
HI EVERYBODY:
Please help, recently purchased a beautiful vehicle with steering wheel problem: won't move in/out, while up/down works. I don't get any noise when try to move in/out. So far checked fuses #1, 19 and 24 they are fine.
I check related posts and it seems that usual concern is tilt feature up/down.
Guys please assist if anyone has ideas
Thanks
Old 10-24-10, 04:17 PM
caddyowner
caddyowner's Avatar
I had the same problem. Luckily, it failed at the fully extended position. $550 to my dealer fixed the problem.
Old 10-24-10, 05:01 PM
Playdrv4me
Playdrv4me's Avatar
The in and out is what typically breaks. It is a complex part to replace, so the dealer is your best solution for this repair. While you have it in there for repair, ask the dealership to turn OFF the Auto exit steering wheel functionality to extend the life of the new motor (unless you absolutely can't get in or out easily without that feature). My dealer turned it off for free.
Old 10-24-10, 06:03 PM
aypues
aypues's Avatar
i had this too, the telescoping was out. the motor was fine, but apparently the steering column had seized and needed to be replaced. It was like $1600 but covered under my CPO warranty.
Old 10-27-10, 10:01 AM
Viged
Viged's Avatar
Thanks for your inputs. Mine isn't covered by CPO warranty, seems that I would have to shell out a lot.
axoskar
08-14-16 08:33 AM
rickyc51
01-11-16 04:36 PM
hms09
07-08-13 01:47 PM
SH212
05-01-08 06:14 PM
99LS400
Maintenance
05-01-04 12:00 AM
Quick Reply: '05 LS430 Telescopic Steering Wheel Won't Move In/Out Retract/Extend
