LS 430 Door Lock Actuator Tutorial
Old Jul 17, 2011 | 08:30 PM
  #31
ddm17's Avatar
ddm17
Hey guys, sorry it took me a while to get back on this. Took the family on a little vacation to Santa Barbara, man I sure miss living there!
I got the door off and took the actuator motor out again. I couldn't tell for sure but I'm pretty certain it was the heat that melted the glue and the zip tie I had on there loosened up........this heat here is terrible!
I added three zip ties to the housing and glued again (just for added measure) and pulled those darn ties super tight. It works great now but we'll see if the heat does it's thing again.
Thanks again guys!!
-Dan
Old Aug 10, 2011 | 03:58 AM
  #32
wittmd03's Avatar
wittmd03
First time to post on this forum, I have a question for Randy B concerning the brushes for the actuator motors. Can you buy replacement brushes? If so, where? This sounds like the cheapest and easiest fix, to me. Of course, I haven't attempted it yet. What is the part number for the new motors. Thanks in advance for your help. I don't think I would have attempted this without it.
Old Aug 11, 2011 | 01:40 PM
  #33
Dajap's Avatar
Dajap
I replaced the lock actuator motor in my 04 LS430 for my front passenger door yesterday using this thread. Getting everything out of the door was easy. Getting to the motor was a little more difficult because I have the EZ door closer which required a little more disassembling. Tip to opening up the motor housing - use a razor and a small hammer to get yourself started and proceed with a small flat head to pry slowly. The hardest part of this whole process was getting the whole unit back into the door. My only advise for that is, be aggressive with the window rail. If you don't move that thing out of the way, you won't ever get the lock actuator back into place. All in all, I'm glad I fixed my problem for about $10 instead of $900.
Old Aug 13, 2011 | 03:37 PM
  #34
Randy B's Avatar
Randy B
Default Brushes.
I did not look for brush replacements. My previous experience in that type of search many decades ago is futile on a motor this size. On 3/4hp or more 110V or 220V motor for say a pump, yes, brushes are commercially available. For a $5-10 complete motor assembly retail, not in my experience.
As for the motor replacement number, please read through the thread, as its in there somewhere, and I don't feel like searching for it right now.
Randy B
Old Aug 15, 2011 | 05:33 AM
  #35
wittmd03's Avatar
wittmd03
Thanks Randy for the info. I replaced the passenger front door acutuator yesterday was very simple after reading the threads. Thanks to all parties responsible for the threads. I bought a new actuator on Ebay, at that time I was looking for information concerning getting door panel off and removing actuator. I wasn't aware of the little motor causing the problem until later. I will if needed, go with your suggested route in the future. Thanks again to all.
Old Aug 21, 2011 | 10:19 AM
  #36
Stout's Avatar
Stout
Is the door lock actuator the same for the EZ close doors? I'll probably just buy the actuator on Ebay and put it in. Then repair the spare and save it in case I need it for another door.
Old Sep 1, 2011 | 03:58 PM
  #37
Stout's Avatar
Stout
Well I just finished replacing the door lock actuator motor on the easy close door model. I'm pretty good at the mechanic thing and this was a *****. Probably 4-5 hours. It was the same motor as the non easy close doors but instead of replacing the brush pack I got out the dremel and ground a flat side on the new motor shaft. The old gear slid right on.
The easy close includes the door latch, the locking mechanism, and the acctuator. The whole assembly is screwed together with a mild adhesive or more likely a sealer. I had to disassemble the thing to get to the motor. But hey, saved $1075 according to the local Lexus dealership prices.
The time required to do this job was increased slightly due to the "extra" plug I found while assembling the door. It was for some box that was on top of the clear plastic on the door. I think it was the smartkey receiver but I'm not sure. While assembling the door I could not remember where this plug went, disassembled the door again, and then found the stupid box sitting on next to the interior panel. Duh...
Done and it works great again.
Old Sep 12, 2011 | 03:13 PM
  #38
1stClass's Avatar
1stClass
I read this DIY post several times thinking this is the right fix for my door lock because I have to manually open and close the door lock on the front passenger door. The smartkey when unlocked, only unlocks the driver and the 2 rear passenger doors; same thing for locking. I initially think it was the little electric motor too. I took this little electric motor out today, and then tested it with a battery. The little electric motor actually spins clockwise and counterclockwise, whichever polarity used. So if my electric motor spins, what else could be the problem? I am assuming for everyone that has posted on this thread, their little electric motor seized and or makes hella loud sounds? So you guys replaced it. But what about for guys like me. Little damn electric motor works. I'm thinking it's electrical? Any thoughts? I'm going to test to see if it's an electrical problem or relay? Or that stupid black box behind the door panel where all the wires plug in to? Could this unit go out?
Old Sep 12, 2011 | 04:31 PM
  #39
1stClass's Avatar
1stClass
Ok, I kind of put the electric motor back in and tested the switch. Fuses are good. It can lock and unlock the driver and rear passenger door locks, but not the front passenger door (this is the door I'm having issues with). The little electric motor spins but barely. It seems like the gears barely move back and forth. Is the electric motor suppose to do constant spinning to move the gear all the way clockwise and stop? Or say counterclockwise and stop when it locks/unlocks? What I'm trying to figure is if the white plastic gears are suppose to keep spinning one direction until it locks or unlocks and stop. If thats the case, then the lock will be able to lock and unlock. Which will then mean my small electric motor is busted and needs replacing? Am I explaining this well?
Old Sep 19, 2011 | 08:48 AM
  #40
rickbrad's Avatar
rickbrad
Just because the motor spins freely while removed is not a good indication that it will move under load. Did you actually install the motor in the other 3 doors to confirm it had enough torque to open the locks on those doors??
You should likely remove the motor and order one from eBay. I just ordered mine last night and hope to get this installed later this week. I am driving my F250 30 each way to work while the door panel is off and it uses a bit more gas, and is not as comfortable.
I will report back when I have success!!
Old Sep 19, 2011 | 04:21 PM
  #41
nautica602's Avatar
nautica602
Just did the install with mabuchi motor from ebay. I ran into a problem though. It works fine locking, but when I unlock there is a grinding noise. I installed and reinstalled the acutator around 5 times double checking my work....same problem. Epoxied everything back to together, and still got the grinding noise. Any suggestions? If not, I will just fork out the $180 for a new one on ebay.
Old Sep 23, 2011 | 05:46 PM
  #42
1stClass's Avatar
1stClass
Yeah this door lock ***** is wack. Freakin Lexus is so damn complicated. All the Hondas I've owned and worked on are so darn easy. But then again, we're talking about a Lexo. So I ended up messing with it more and trying to figure out if it was the gears or what not and it flew out along with the spring. Now I can't put it back on. Looks like I'm going to have to search for a used unit from a junkyard. Don't think I'll spend the dollar to replace the whole stupid unit got quoted remember it was like 600 or 700 for it. Gay. Anyhow, so went back manually locking and unlocking the door. Stupid Lexo *****.
Old Sep 25, 2011 | 06:37 AM
  #43
rickbrad's Avatar
rickbrad
Thanks so much to the OP and all the contributors. I bought the motor on eBay for less than $7 shipped and was able to get my passenger door lock actuator functioning again.
I thought I was going to have to throw in the towel at the end because I put it all back together (almost) and the lock still did not move. Well, as it turns out, I had pulled one of the connectors off of the door computer when taking the door panel off - thinking I was going to take all of them loose to remove the panel. Anyway, I plugged it back in and it works perfectly.
I will add something about the window track. There is no reason to "get agressive" as is mentioned in an earlier post. If you pull the rubber/felt window guide out of the track it is possible to pull it out of the door. I discovered this because I try to pry it out of the way. So I had to remove it to straighten it.
Finally, I found it easier to file the flat on the shaft rather than use the original armature. The shaft is not hardened and a sharp file re-shaped the flat easily in 5 min. I felt this was much more easy to control than a rotary tool. I held the motor in a vice with the shaft supported by a block of wood.
Thanks again!
Old Sep 26, 2011 | 08:04 AM
  #44
nautica602's Avatar
nautica602
Which part do you need? I am selling my old actuator if you need it, just switch out your old motor assembly. My old motor assembly works fine, but grinds when unlocking. I decided just to purchase the whole acutator assembly off ebay for $180 shipped brand new. There are a few more if you do a search on ebay.
Old Sep 27, 2011 | 04:12 PM
  #45
rickbrad's Avatar
rickbrad
Has anyone done the same procedure on the rear door of an LS430? I just got my front passenger DLA working and the rear is not acting up!
