Replacing stock antenna with Sirius antenna?
Old 07-31-10, 07:02 AM
TTBomB
TTBomB's Avatar
Default Replacing stock antenna with Sirius antenna?
Hi all,
2005 LS-430 UL with Mark Levinson system, factory nav etc.
I am having my Sirius unit (Vais Tech. SL2S) installed on Monday.
I have read on the forum here that the stock roof antenna is not being used.
I was wondering if we can remove and replace with the Sirius antenna or possible another antenna from a Lexus (or any car for that matter) that has a Sirius antenna integrated within.
Does the LS-460 shark fin have a Sirius antenna integrated within?
Any thoughts, suggestions would be great!
Thanks, Tom
Old 07-31-10, 08:16 AM
AlexusAnja
AlexusAnja's Avatar
Default Satellite antenna
Originally Posted by TTBomB
Hi all,
Thanks, Tom
The roof antenna was used for the Lexus-link even if you were not equipped with it. Guess Lexus found it easier to just have the thing on every car than to have it when you had the Lexus-link. The antenna is a satellite antenna, so I would imagine you could easily hook it up with your VAIS and get satellite radio reception through it.
Others more knowledgable will chime in that have done it before.
Old 07-31-10, 01:49 PM
KaiserSea1
KaiserSea1's Avatar
I have two antennas. Looks a little silly.
Old 08-03-10, 05:18 AM
TTBomB
TTBomB's Avatar
They have not gotten to the roof antenna yet.
Has anyone else tried to hook sirius up to the factory antenna? Is it compatible?
Still looking for any suggestions.
Old 08-07-10, 07:43 PM
chunkyda
chunkyda's Avatar
You could use the roof location since there is a hole and such, however a satellite antenna is completely incompatible with that factory thing. XM is 2,332.50 through 2,345.00 MHz and Sirius is 2,320.00 through 2,332.50 MHz. If you find a SAT antenna that looks cool, let us know.
anniversar
02-28-11 07:52 PM
JKN2000
03-24-10 04:23 PM
gdi
12-25-08 03:07 PM
froboy272
10-10-08 09:37 PM
Quick Reply: Replacing stock antenna with Sirius antenna?
