How much brake pedal travel before stopping?
Hey all,
So the only aspect of controlling my LS430 that bothers me at all is the brake pedal engagement. It feels like the pedal needs to travel about 2 inches before I feel any noticeable braking power. If I slam on the pedal to engage the active brake enhancement, it engages higher up.
Once the brakes engage (whether 2 inches down when I push slowly or higher up when I push quickly) they modulate very well and provide progressive, strong stopping power.
Is it normal for the brakes to feel like this? Everyone seems to say that the brakes are soft on a Lexus. I don't think there's a problem with the master cylinder or the brake booster - the brakes are firm once they engage and they can stop the car plenty fast. The rotors aren't warped and the brakes are silent and smooth. I don't think there is air in the lines.
I just wish that the pedal engaged higher up. Is this a common problem, and are there any solutions? I can live with it and get used to it, but when I drive our prius it takes me a minute or two before I get used to the quick pedal engagement again.
Thanks!
Thanks!
I have not noticed any excessive brake pedal travel before brakes engage. My pedal engages the brakes almost at once I'd say. The brake system is hydraulic so under ideal conditions it acts like a solid linkage between pedal and brake pad.
First I'd first check the shims and brake pads - make sure they are correct parts and installed correctly, then check pads for excessive wear - that can cause more pedal travel.
Then I'd have the brake fluid flushed and see if that corrects the problem. If the fluid is brand new just get the brakes bled.
Then check for problem with master cylinder vacuum or seals.
i was thinking along the cheapest and most likely culprit, the brake pads. mine engages very quickly and when i go from other vehicles or let others drive my ls the powerful and responsive braking is usually one of the first thing noticed or mentioned...
not sure about the v6 thing i just never thought of it like that but yesterday one of my neighbors was talking about it being fwd and i kept telling him that it was rwd,, he was like are you sure, i said yes i am sure, and he was comparing it to his fwd camry i said well mine isnt fwd its rwd... he seemed confused.
The brakes have electronic brake assist, which means when the pedal is jammed on, the system detects the quicker pressing and electronically applies more pressure to the system. What I don't know for sure, is if there is an actual mechanical connection between pedal and system, or if it's all electronic.
This is why when you apply normally, it feels a little soft, but when you have to jam on it, it feels "stronger."
[QUOTE=adams430;5211762]Hey all,
Thanks![/QUOTE
I agree. I know what you are talking about. I also feel like I need to press a little too far to get the brakes to engage, but they are indeed plenty strong and smooth. The brakes do feel a little soft, especially comared to the IS I had for a while. The brakes were night and day. I would assume that my CPO's brakes would be in tip top shape at the time of selling 2 months ago.
Thanks![/QUOTE
The brakes on the LS use a traditional vacuum booster rather than the electronic brake booster on the LX/GX. On the electronic booster, if the pump fails, you basically lose all braking to the rear wheels and have half braking pressure on the front, so you have to stomp on the brakes in any hopes of stopping a 3-ton vehicle.
The brakes on my LS are smooth to apply. I had a new IS250 dealership loaner car the other day and the brakes were very touchy - way more sensitive than I'm used to and therefore hard to smoothly slow down the car. I've test driven a few low-end Mercedes in the past and their brakes were very touchy as well.
I think the LS was designed to have soft brakes. Seems to complement the Electronically Controlled Throttle (ECT) which smooths throttle response and acceleration when in Normal mode. I much prefer the feel of the LS brakes over the IS brakes.
I love the brake feels in my LS430 also. Soft enough to be comfy for a luxury car, but very strong when you step on it. It is painful if you slam on it, the suspension is so soft and the 4 pistons brakes are so strong, it makes me sick.
After playing with it a lot, I think there's actually some air in the brake lines. With the car off and the brake booster empty, if I push the brakes softly they have that extra inch+ of play that bothers me. If I pump them rapidly it doesn't. The dealer should have changed the brake fluid in the 90k service they performed right before I bought the car - I'm taking it by tomorrow to see if I can get them to fix it. I'll be pretty pissed if they won't stand behind their own work.
