Rain sensor windsheild
Old 11-27-09, 01:30 PM
lexman52
lexman52's Avatar
Default Rain sensor windsheild
Is a rain sensor windshield standard on a 2001 430. If so i guess mine does not work??
Old 11-27-09, 11:48 PM
stock_sc
stock_sc's Avatar
yes its standard on a 01. just curious is it on the second click down?
Old 11-28-09, 06:28 AM
GeorgeT
GeorgeT's Avatar
It's not really the windshield that senses rain, it's a module glued to the windshield behind the mirror. It works, I think, by measuring light refraction - when the winshield gets wet, the light refraction changes and the wipers activate. If the winshield is replaced, the correct re-attachment of this module is critical for proper function.
Old 11-28-09, 06:45 AM
alanchad
alanchad's Avatar
Yes
First position = off
Second position = Rain-sensing
Old 11-28-09, 06:55 AM
jimmyford1
jimmyford1's Avatar
If the windshield has been replaced with a non-Lexus windshield (Pinkertons is one) it may not work.
Old 11-28-09, 02:19 PM
bigcory
bigcory's Avatar
So since we have confirmed the switch is indeed in the correct position
Check the windshield for the manufactor stamp. Off hand i'm not sure where it is, but I think I remember seeing it either on the bottom or top of the drivers side.
Second, take a look at that box thats behind the rearview mirror. I was reading a post from another member recently where the shop reinstalled that sensor with the gel pad and had gotten some air bubbles in it that prevented it from working correclty. His were going on and off sporatically.
Third up, there is most likely a fuse for that somewhere. I'd take a look at that as well.
Fourth, never heard of this being related to washers or that sensor, but are cars seem to going really wacky when the battery is about to go. If all else fails, have a local autostore check your battery before you pay a gazillion dollars to have the dealerships check it out.
Old 11-28-09, 02:37 PM
lexman52
lexman52's Avatar
Thank guys i do have it in auto mode. Windshield does have lexus name on it, will look for fuse thou i would think fuse would effect other things. Steve
FLYCT
RX - 3rd Gen (2010-2015)
10-07-22 06:39 AM
Morfeeis
08-01-18 07:39 AM
sgmstr
07-21-16 06:09 PM
adman0468
12-14-14 06:29 AM
Vinniety
GX - 1st Gen (2004-2009)
06-24-09 05:59 AM
Quick Reply: Rain sensor windsheild
