Camber wear needed advise
Old 12-10-08, 09:36 PM
i3leusky
i3leusky's Avatar
Default Camber wear needed advise
im having really bad camber wear in the rear and a little bit in the front. What are the different camber kit out there and which one would you guys prefer for 03 ls430?
Old 12-11-08, 07:37 PM
ancdmd
ancdmd's Avatar
I got the +1 factory rear camber bars because I wore the crap out of the insides of my 20" tires with the car lowered. The bars really make a difference and put the tires more vertical where they should be.
Old 12-11-08, 08:17 PM
big_blzr94
big_blzr94's Avatar
the front has factory adjustment on the lower control arm for camber. Kit is required for caster.
Old 12-14-08, 12:17 AM
i3leusky
i3leusky's Avatar
What is the bar call? where can i buy it? how much is it? and does this go for front or rear? i need the rear badlly thank you
Old 12-14-08, 01:33 PM
eyft23
eyft23's Avatar
the bar can be found at your local lexus dealer. just asj them for the rear lower control arms section in their computer and it will show up with 3 different types of arms. one for positive camber, one for negative camber, and one with no camber.
i dont remember how much it cost, but i think each dealer is different.
the arms are for only the rear.
if you are looking for a complete adjustment for your suspension you might want to find someone who can bring in nagisa auto. mode parfume sells them also under their name just to make some money because a lot of poeple dont know of nagisa auto. they make fully adjustable suspension arms for the lexus ls430 for the front and rear of your car.
Old 12-14-08, 04:36 PM
big_blzr94
big_blzr94's Avatar
nagisa auto does not show anything on there site for the LS430 only the 400.
Old 12-16-08, 01:12 AM
i3leusky
i3leusky's Avatar
So do i need possitive, negative, or no camber?
Old 12-17-08, 10:36 AM
ancdmd
ancdmd's Avatar
You need the 1-degree positive bars. Right now you have the standard bars, which give you too much negative camber with the car lowered. The bars cost around $300 total if I remember correctly, and I ordered them from Carson Toyota in California. My tire shop installed them before doing an alignment.
Old 12-17-08, 11:04 PM
REV-01
REV-01's Avatar
the most inexpensive way is get the oem one.
the nagisa auto one is worth it only if you want more negative camber. normal people will not consider those parts for "tire wear issue"
Old 12-18-08, 05:29 AM
Neo300
Neo300's Avatar
Are you sure its camber? It kinda sounds like a tow issue. Try spending 60 something dollars on a basic alignment before dropping a couple hundred on these bars.
Old 12-19-08, 12:38 PM
eyft23
eyft23's Avatar
actually nagisa does sell them for the celsior 30/31( lexus ls430)
here's a translated version. try go down the opage and you can see that they do.
http://babelfish.yahoo.com/translate...rUrl=Translate
jwynn
Performance & Maintenance
09-01-17 04:26 AM
Sleepy2is
05-30-15 01:19 PM
HAiS250
Suspension and Brakes
12-16-11 06:25 PM
4uhaterz
07-16-11 02:56 PM
SH430
05-26-09 02:37 AM
Quick Reply: Camber wear needed advise
