LS 430 Transmission Fluid Replacement
I heard that the transmission fluid for this model is sealed. So does it need replacement? If yes, how often?
Thanks!
Thanks!
Transmission Fluid
The filter is sealed inside the transmission and pan, but I believe there is a plug and drain and fill. I could be wrong. It is advertised as "lifetime" I believe... but if this LS430 holds out like previous generations... 200K+ is a long time to drive on the same fluids.
3UZ-FEEEE
