LS430 Fog Light Conversion (HID)
#46
ok... not that i don't believe you, but other than you saying it's superior, why is it better? at the very least it's cheaper than the td version...
#47
Former Sponsor
Hi,
We have tested the ballast used in that kit and have found a couple of things:
1) The ballast is extremely power hungry meaning that you will find more often that not that your lights will not ignite simultaneously (regardless if you use a relay harness or not).
2) The ballast is not as efficient as our Volt ballast meaning that lifespan will be much shorter.
3) In truth, I can't really tell anything about the bulbs as it's hard to tell from that pic.
Hope this helps,
Steve
Hope this helps,
Steve
#55
Former Sponsor
Thanks Danny. I was considering this kit from Amazon. Any comments on quality or the power draw. I realize it's not from your company but the price is good.
Amazon.com: OPT7® Blitz Fog Light 25w HID Kit - 9006 (6000K, Lightning Blue) - 2 Year Warranty: Automotive
Danny
#56
Ok after some serious research through various threads I have made the decision to post here for my foglight SWITCH question.
I am trying to make the foglights switch independent from all the lights using the oem switch on the column and have a 04 430UL. Any links to mod diy would be greatly appreciated. Thanks guys!
#57
https://www.clublexus.com/forums/ls4...-on-relay.html
#58
Check out this post... It has some of the information you're looking for.
