My first DIY for the LS430...Here comes the BOOM...
Old 04-02-11, 08:25 PM
  #166
Muti007
Muti007's Avatar
Ok, so I never got an answer about wiring it in series, so I just installed the Polk today using the original connection. Sounds good so far but I have a question. Anyone running a similar 4 ohm sub flawlessly? I've read some posts where people say they shut down after a while, others where people seemed happy. Should I expect it to shut down on me or should it work ok as is? The install was a real pita, hoping not to have to tear into it again if I don't have to.
Thanks again.
Old 04-03-11, 12:15 PM
  #167
SQuester
SQuester's Avatar
Old 04-03-11, 03:22 PM
  #168
Muti007
Muti007's Avatar
Originally Posted by SQuester
Can you please explain what were looking at here? The speaker obviously just has one + and 1 -. You connect them to the amps + and -. Where does that second set of + and - come from?
Old 04-03-11, 03:34 PM
  #169
MrXerox
MrXerox's Avatar
A dual voice coil (DVC) sub will have 2 + and 2 - terminals. You wire as illustrated to get the added resistance value.
Old 04-03-11, 03:35 PM
  #170
Muti007
Muti007's Avatar
The Polk I ordered is dual coil, but only one set of terminals.
Old 05-15-11, 01:04 PM
  #171
dejavu157
dejavu157's Avatar
I am still lost in removing the subs in a 01 UL. Does anyone have a DIY with more pictures?
Old 06-03-11, 06:58 AM
  #172
Zahir
Zahir's Avatar
Hi. Thank you for this great info / posting. I am a new a Lexus Owner....just bought the 04 LS430 and unfortunately the Woofer was blown. :-( I want to place the order and want to DIY...can you please tell me the exact Stock number that you place order for your woofer. Also possible can you send pic of taking out the original woofers would be greatly appreciate it. Maybe be step by step pic of removing and installing the new woofers.
Many Thanks.
Zee
Old 09-03-11, 01:42 PM
  #173
2004TOYO
2004TOYO's Avatar
Hey folks, I found a JL Audio 8w0 12 ohm on Ebay. Should be a perfect fit. Ill keep ya posted
Old 06-07-12, 10:37 AM
  #174
vamel
vamel's Avatar
Originally Posted by xsuperjoex
As you guys know my subwoofer was blown in my UL....boy did that "grind my gears" and at a convienent 61K miles it's out of warranty...so I decided to call up the stealer to find out how much a new ML subwoofer would be for and 01 430....ready for this...
$288
Well that really didn't fair very well with me so I decided to give Tweeter a call to find out how much another 8" subwoofer would be.
JL W0 = $89 not bad at all! (not great either I'm just comparing prices with the stealer)
Well here are my pics...
Hey xsuperjoex, would you please let me know how you made the terminal connections? I mean after you unsoldered the red and black wires from the ML sub, where did you connect those, which color to positive + and which went to negative - ?
Thanks in advance for your input.
Old 11-10-12, 11:08 AM
  #175
Lynzoid
Lynzoid's Avatar
Reviving the thread.
Ok, i have euro president pkg with sunshade and rear a/c as well as power rear seats.
What is the best and most safe way to replace my sub? Without damaging 1k usd sunshade assy and not breaking anything.
Thanks in advance.
Old 02-22-13, 12:39 AM
  #176
Vincent123
Vincent123's Avatar
My factory ML subwoofer is blown. Looking for a 8" rear deck replacement. Found 2 options with 8ohm.
The Kicker C88 and the Rockford Fosgate P1S8-8
Both are same price. Which would you choose and why?
I will be powering it up with my factory ML amp.
http://www.sonicelectronix.com/cat_f...woofers-8.html
Old 02-22-13, 04:36 PM
  #177
bootnylee
bootnylee's Avatar
I would bypass the factory amp and get a mono amp so the new sub runs the right amount of power
Posted from ClubLexus.com App for Android
Old 02-28-13, 12:47 AM
  #178
TSA1
TSA1's Avatar
Would his be hard to do?
Old 03-08-13, 01:34 PM
  #179
HTOWNLS500
HTOWNLS500's Avatar
I replaced my blown ML sub with a Kicker comp 8-ohm and it sounds pretty good. Has a nice amount of bass, although not as "snappy" as the stock ML sub. You can tell its slightly underpowered, but it still sounds better than a crackling, fluttering sub. Thanks to all the info and write-ups on here that helped me with this. I did however have to get creative with mounting the sub with the old ring from the ML sub. Screwing it in wasnt working due to the angles and such, so I had to use zip ties! Don't judge me! lol
Old 04-28-13, 09:46 PM
  #180
BMW7_LS430
BMW7_LS430's Avatar
I have Rockford Fosgate Punch P1 P1S88 8-Inch 150-Watt Subwoofer - 8 Ohm
http://www.amazon.com/Rockford-Fosga.../dp/B001HBJ1KG
I had it in my home theater subwoofer for some time and it sounds great. Now it is back in the box waiting to go in LS whenever original one (now glued) needs complete replacement.
I don't know about the Kicker. Post above says Kicker sounds good but installation was tricky.
Quick Reply: My first DIY for the LS430...Here comes the BOOM...
